Hello,
I am using an Arduino nano that is reading from 2 analog sensors at a rate of 1khz, and sends serial data to ESP8266 NodeMCU that then should send data to laptop over WIFI. The issue is that as I receive the data on my laptop, the data rate is lower (around 800 readings/sec), and is varying a lot +- 50 readings. I do some computations that require the sampling frequency to be almost 1khz, so this is causing troubles. I would appreciate some feedback on the code below.
Arduino:
#include <SoftwareSerial.h>
//Initialise Arduino to NodeMCU (5=Rx & 6=Tx)
SoftwareSerial nodemcu(5, 6);
unsigned int ch1, ch2;
byte buffer[10];
nodemcu.begin(57600);
Serial.println("Program started");
unsigned long t;
static uint32_t last_conversion_time = micros();
if (micros() - last_conversion_time >= 1000) {
last_conversion_time += 1000;
ch1 = analogRead(A0);
ch2 = analogRead(A1);
buffer[0] = '<';
buffer[1] = (ch1 >> 8);
buffer[2] = ch1 % 256;
buffer[3] = (ch2 >> 8);
buffer[4] = ch2 % 256;
buffer[5] = '>';
nodemcu.write(buffer, 6);
Serial.print(buffer[1]*256+buffer[2]);
Serial.print(buffer[2]*256+buffer[4]);
NodeMcu code:
#include <ESP8266WiFi.h>
int port = 5555; //Port number
WiFiServer server(port);
//Edit this to add your network ssid and password
//const char *ssid = "";
//const char *password = "";
const int BUFFER_SIZE = 16;
byte buf[BUFFER_SIZE];
SoftwareSerial nodemcu(D6, D5);
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, password); //Connect to wifi
// Wait for connection
Serial.println("Connecting to Wifi");
Serial.print(".");
Serial.println("");
Serial.print("Connected to ");
Serial.println(ssid);
Serial.print("IP address: ");
server.begin();
Serial.print("Open Telnet and connect to IP:");
Serial.print(WiFi.localIP());
Serial.print(" on port ");
Serial.println(port);
WiFiClient client = server.available();
if (client) {
if(client.connected())
Serial.println("Client Connected");
while(client.connected()){
//discard incomplete readings
if(nodemcu.available() > 5)
buf[0] = nodemcu.read();
if(buf[0] == '<')
for(int i = 1; i < 6; ++i)
buf[i] = nodemcu.read();
if(buf[5] == '>')
ch1 = buf[1]*256 + buf[2];
ch2 = buf[3]*256 + buf[4];
client.print(ch1);
client.print(",");
client.println(ch2);
client.stop();
Serial.println("Client disconnected");
