VB.net. NI VISA. RawIO.Write not working
You should be able to suppress the reset. In below C# snippet, sp is a serial port object and cbXXX are two check boxes.
            sp.DtrEnable = cbDTR.Checked;
            sp.RtsEnable = cbRTS.Checked;
            sp.ReadTimeout = Constants.rxTimeout * 1000;
            try
                sp.Open();
                btnConnect.Enabled = false;
            catch (Exception ex)
                MessageBox.Show(ex.Message, "Serial port error", MessageBoxButtons.OK, MessageBoxIcon.Error);
This should also work in VB.net; might need a small modification to adapt to the language.
Check the documentation of the NationalInstruments.Visa library to see if a similar feature is supported.
Notes:
  1. You can also place your VB code in code tags :wink:
  2. You can let others know that your problem has a solution by clicking the solution checkbox of the most useful reply (post #2).
