Currently, i only have a program that the user choose either short or long using check box, but i cant make a program that you have to enter the quantity on textbox and every quantity is equal to how many rotation of the stepper to get the paper out of the rack.
the problem with this check box is the rotation depends on the arduino steps. I tried it with textbox but it keeps on rotating and didn’t stop.
my code is very basic so… yeah please help me
vb 2010
Imports System.IO
Imports System.IO.Ports
Imports System.Threading
Public Class Form1
Shared _continue As Boolean
Shared _serialPort As SerialPort
Dim WithEvents SerialPort1 As New SerialPort()
Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
SerialPort1.Close()
SerialPort1.PortName = “Com5”
SerialPort1.BaudRate = 9600
SerialPort1.DataBits = 8
SerialPort1.Parity = Parity.None
SerialPort1.StopBits = StopBits.One
SerialPort1.Handshake = Handshake.None
SerialPort1.Encoding = System.Text.Encoding.Default
End Sub
Private Sub Button4_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button4.Click
If CheckBox1.Checked = True Then
SerialPort1.Open()
SerialPort1.Write(“0”)
SerialPort1.Close()
ElseIf CheckBox2.Checked = True Then
SerialPort1.Open()
SerialPort1.Write(“1”)
SerialPort1.Close()
End If
End Sub
Private Sub CheckBox1_CheckedChanged(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles CheckBox1.CheckedChanged, CheckBox2.CheckedChanged
Dim senderCheck As CheckBox = DirectCast(sender, CheckBox)
For Each checkbox In {CheckBox1, CheckBox2}
If checkbox IsNot senderCheck Then
checkbox.Enabled = Not senderCheck.Checked
End If
Next
End Sub
End Class
Arduino Code
#include <Stepper.h>
#define STEPS 60
Stepper stepper1(STEPS, 4, 5, 6, 7);
Stepper Stepss(STEPS, 8, 9, 10, 11);
while (Serial.available() == 0);
int val = Serial.read() - ‘0’;
Serial.println(val);
if (val==0)
stepper1.setSpeed(460);
delay(50);
stepper1.step(7000);
delay(10);
digitalWrite(2,LOW);
digitalWrite(3,LOW);
digitalWrite(4,LOW);
digitalWrite(5,LOW);
else if (val==1)
Stepss.setSpeed(460);
delay(50);
Stepss.step(-7000);
delay(10);
digitalWrite(8,LOW);
digitalWrite(9,LOW);
digitalWrite(10,LOW);
digitalWrite(11,LOW);
