Vc0706 Image stuck with Esp32
Hello.
I've connected a Vc0706 camera module to an
esp32 to receive the image and sended to a
Webserver.
After some time of operating without a problem.
The system blocked after sending me a cropped Pic.
pic.php (1)
This is the sketch used.
Serial Pass-through.new.ino (4.8 KB)
I'm going crazy. Last time I've used this device it
worked without problem during 1 whole week.
Code from post#1
#include <WiFi.h>
  SerialPassthrough sketch
  Some boards, like the Arduino 101, the MKR1000, Zero, or the Micro, have one
  hardware serial port attached to Digital pins 0-1, and a separate USB serial
  port attached to the IDE Serial Monitor. This means that the "serial
  passthrough" which is possible with the Arduino UNO (commonly used to interact
  with devices/shields that require configuration via serial AT commands) will
  not work by default.
  This sketch allows you to emulate the serial passthrough behaviour. Any text
  you type in the IDE Serial monitor will be written out to the serial port on
  Digital pins 0 and 1, and vice-versa.
  On the 101, MKR1000, Zero, and Micro, "Serial" refers to the USB Serial port
  attached to the Serial Monitor, and "Serial1" refers to the hardware serial
  port attached to pins 0 and 1. This sketch will emulate Serial passthrough
  using those two Serial ports on the boards mentioned above, but you can change
  these names to connect any two serial ports on a board that has multiple ports.
  created 23 May 2016
  by Erik Nyquist
uint8_t stopFrame[] { 0x56, 0x00, 0x36, 0x01, 0x00};
uint8_t startFrame[] { 0x56, 0x00, 0x36, 0x01, 0x02};
uint8_t lengthbuffer[] {0x56, 0x00, 0x34, 0x01, 0x00};
uint8_t startMotion[] {0x56, 0x00, 0x37, 0x01, 0x01};
uint8_t MotionStatus[] { 0x56, 0x00, 0x38, 0x00};
uint8_t readBuffer[] {0x56, 0x00, 0x32, 0x0C, 0x00, 0x0A, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x00};
uint8_t Motionparam1[] {0x56, 0x00, 0x43, 0x01, 0x01};
uint8_t Motionparam2[] {0x56, 0x00, 0x43, 0x01, 0x02};
uint8_t Motionparam3[] {0x56, 0x00, 0x43, 0x01, 0x03};
uint8_t Motionparam4[] {0x56, 0x00, 0x43, 0x01, 0x04};
uint8_t SetMParam1[] {0x56, 0x00, 0x42, 0x03, 0x00, 0x01, 0x01};
uint8_t reponse[1000];
int phdelay = 30;
WiFiClient client;
void printVector(uint8_t *vector, unsigned int nubmer)
  for(unsigned int i = 0; i< nubmer;++i)
    Serial.print(" ");
    Serial.print(vector[i], HEX);
  Serial2.begin(115200);//, SERIAL_8N1, 16, 17);
  WiFi.begin("Freebox-599EFF","key");
  while (WiFi.status() != WL_CONNECTED)
    Serial.print(".");
    pinMode(2, OUTPUT);
Serial2.write(SetMParam1, 7); Serial2.flush();
int ib = Serial2.readBytes(reponse, 10);
printVector(reponse, ib);
  int i = 0;
  char querystring[200];
  while(true)
    Serial.println("Start");
    Serial2.write(startFrame, 5);
    Serial2.flush();
    Serial2.readBytes(reponse, 5);
    Serial2.write(stopFrame, 5);
    Serial2.flush();
    Serial2.write(lengthbuffer, 5);
    Serial2.flush();
    Serial2.readBytes(reponse, 9);
      int iL = 0;
      iL = reponse[5];
      iL = iL << 8;
      iL += reponse[6];
      iL = iL << 8;
      iL += reponse[7];
      iL = iL << 8;
      iL += reponse[8];
      Serial.print("Size : ");
      Serial.println(iL);
    if(client.connect("192.168.1.16", 80))
      client.println("POST /newpic.php HTTP/1.1");
      client.println("Host: 192.168.1.16");
      client.println("Content-Type: multipart/form-data; boundary=---------------------------139955009910887227731308057551");
      sprintf(querystring, "Content-Length: %d", 230 + iL);
      client.println(querystring);
      client.println();
      client.println("-----------------------------139955009910887227731308057551");
      client.println("Content-Disposition: form-data; name=\"file\"; filename=\"datapic.jpg\"");
      client.println("Content-Type: application/x-php");
      client.println();
      int addr = 0;
      int sizeR = iL;
        readBuffer[6] = (addr >> 24) & 0xFF;
        readBuffer[7] = (addr >> 16) & 0xFF;
        readBuffer[8] = (addr >> 8) & 0xFF;
        readBuffer[9] = (addr & 0xFF);
        readBuffer[10] = (sizeR >> 24) & 0xFF;
        readBuffer[11] = (sizeR >> 16) & 0xFF;
        readBuffer[12] = (sizeR >> 8) & 0xFF;
        readBuffer[13] = (sizeR & 0xFF);
        Serial2.write(readBuffer, 16);
        Serial2.flush();
        int u = 1000;
        while(sizeR != 0)
          u = min(1000, sizeR);
          Serial2.readBytes(reponse, u);
          client.write(reponse, u);
          sizeR = sizeR - u;
      client.println();
      client.println("-----------------------------139955009910887227731308057551--");
      client.println();
      while (client.available() == 0);
      String line;
      while(client.available())
        line = client.readStringUntil('\r');
   //   phdelay = line.toInt();
    Serial2.flush();
When the program stops does it stop at executing the same code?
