Pylon,
I'm using the adafruit example sketch. I'll include it at the bottom of this post, because it's pretty long.
I've also tried a sketces from bildr and sparkfun.
I tried using SoftwareSerial because I know the Leonardo handles serial communication differently and I thought it might help.
Here's the full code (which works fine with an Uno):
// Downloaded from GitHub - adafruit/Adafruit-VCNL40X0-PCB: Arduino code for the VCNL4000 all-in-one proximity/light sensor
// Example sketch for talking to the VCNL4000 i2c proximity/light sensor
// Written by Adafruit! Public domain.
// To use: Connect VCC to 3.3-5V (5V is best if it is available), GND to
// ground, SCL to i2c clock (on classic arduinos, Analog 5), SDA
// to i2c data (on classic arduinos Analog 4). The 3.3v pin is
// an ouptut if you need 3.3V
// This sensor is 5V compliant so you can use it with 3.3 or 5V micros
// You can pick one up at the Adafruit shop: VCNL4010 Proximity/Light sensor : ID 466 : $7.50 : Adafruit Industries, Unique & fun DIY electronics and kits
#include <Wire.h>
// the i2c address
#define VCNL4000_ADDRESS 0x13
// commands and constants
#define VCNL4000_COMMAND 0x80
#define VCNL4000_PRODUCTID 0x81
#define VCNL4000_IRLED 0x83
#define VCNL4000_AMBIENTPARAMETER 0x84
#define VCNL4000_AMBIENTDATA 0x85
#define VCNL4000_PROXIMITYDATA 0x87
#define VCNL4000_SIGNALFREQ 0x89
#define VCNL4000_PROXINITYADJUST 0x8A
#define VCNL4000_3M125 0
#define VCNL4000_1M5625 1
#define VCNL4000_781K25 2
#define VCNL4000_390K625 3
#define VCNL4000_MEASUREAMBIENT 0x10
#define VCNL4000_MEASUREPROXIMITY 0x08
#define VCNL4000_AMBIENTREADY 0x40
#define VCNL4000_PROXIMITYREADY 0x20
Serial.println("VCNL");
Wire.begin();
uint8_t rev = read8(VCNL4000_PRODUCTID);
if ((rev & 0xF0) != 0x10) {
Serial.println("Sensor not found :(");
while (1);
write8(VCNL4000_IRLED, 20); // set to 20 * 10mA = 200mA
Serial.print("IR LED current = ");
Serial.print(read8(VCNL4000_IRLED) * 10, DEC);
Serial.println(" mA");
//write8(VCNL4000_SIGNALFREQ, 3);
Serial.print("Proximity measurement frequency = ");
uint8_t freq = read8(VCNL4000_SIGNALFREQ);
if (freq == VCNL4000_3M125) Serial.println("3.125 MHz");
if (freq == VCNL4000_1M5625) Serial.println("1.5625 MHz");
if (freq == VCNL4000_781K25) Serial.println("781.25 KHz");
if (freq == VCNL4000_390K625) Serial.println("390.625 KHz");
write8(VCNL4000_PROXINITYADJUST, 0x81);
Serial.print("Proximity adjustment register = ");
Serial.println(read8(VCNL4000_PROXINITYADJUST), HEX);
// arrange for continuous conversion
//write8(VCNL4000_AMBIENTPARAMETER, 0x89);
uint16_t readProximity() {
write8(VCNL4000_COMMAND, VCNL4000_MEASUREPROXIMITY);
while (1) {
uint8_t result = read8(VCNL4000_COMMAND);
//Serial.print("Ready = 0x"); Serial.println(result, HEX);
if (result & VCNL4000_PROXIMITYREADY) {
return read16(VCNL4000_PROXIMITYDATA);
delay(1);
// read ambient light!
write8(VCNL4000_COMMAND, VCNL4000_MEASUREAMBIENT | VCNL4000_MEASUREPROXIMITY);
while (1) {
if ((result & VCNL4000_AMBIENTREADY)&&(result & VCNL4000_PROXIMITYREADY)) {
Serial.print("Ambient = ");
Serial.print(read16(VCNL4000_AMBIENTDATA));
Serial.print("\t\tProximity = ");
Serial.println(read16(VCNL4000_PROXIMITYDATA));
delay(10);
delay(100);
// Read 1 byte from the VCNL4000 at 'address'
uint8_t read8(uint8_t address)
uint8_t data;
Wire.beginTransmission(VCNL4000_ADDRESS);
#if ARDUINO >= 100
Wire.write(address);
#else
Wire.send(address);
#endif
Wire.endTransmission();
delayMicroseconds(170); // delay required
Wire.requestFrom(VCNL4000_ADDRESS, 1);
while(!Wire.available());
#if ARDUINO >= 100
return Wire.read();
#else
return Wire.receive();
#endif
// Read 2 byte from the VCNL4000 at 'address'
uint16_t read16(uint8_t address)
uint16_t data;
#if ARDUINO >= 100
#else
Wire.send(address);
#endif
Wire.requestFrom(VCNL4000_ADDRESS, 2);
#if ARDUINO >= 100
data = Wire.read();
data <<= 8;
data |= Wire.read();
#else
data = Wire.receive();
data <<= 8;
data |= Wire.receive();
#endif
return data;
// write 1 byte
void write8(uint8_t address, uint8_t data)
#if ARDUINO >= 100
Wire.write(data);
#else
Wire.send(address);
Wire.send(data);
#endif
