VCNL4040 ambient sensor i2c and serial in loop after some time arduino nano freeze and both communication failed, when we restart serial communication comes again but I2C not...
please look into my code, may be i have done something wrong....
#include <AT24Cxx.h>
#include <SoftwareSerial.h>
#include <Wire.h>
//Click here to get the library: http://librarymanager/All#SparkFun_VCNL4040
#include "SparkFun_VCNL4040_Arduino_Library.h"
#define DEBUG 0
#define DATA 7 //PD3
#define CLOCK 4 //PD4
#define LATCH 5 //PD5
#define OE 6 //PD6
#define DP1 A0
#define DP2 A1
#define DP3 A2
#define DP4 A3
#define pinCONTROL 2
#define rxPin 2
#define txPin 3
#define i2c_address 0x50
byte temps[4];
unsigned char MODULE_ID[6] = {'0', '0', '.', '0', '2', '\0'};
byte MyAddress[2] = {48,50};
int a[32];
int j[4]={24,16,8,0};
unsigned char pre[5];
unsigned int ambientValue;
unsigned int proxValue;
unsigned int whiteValue;
int brightness;
byte byte_receive;
byte state=0;
byte cont=1;
byte trace_OK=0;
byte data[12];
byte buf[3];
long previousMillis = 0;
unsigned long currentMillis;
long interval = 5000;
unsigned int VAL;
AT24Cxx eep(i2c_address, 32);
SoftwareSerial RS485(rxPin, txPin);
VCNL4040 proximitySensor;
void PinConfigure(){
pinMode(DATA, OUTPUT);
pinMode(CLOCK, OUTPUT);
pinMode(LATCH, OUTPUT);
pinMode(pinCONTROL,OUTPUT);
RS485.begin(9600);
PinConfigure();
Wire.begin(); //Join i2c bus
proximitySensor.begin(); //Initialize the sensor
TWBR = 12;
//Turn on everything
proximitySensor.powerOnProximity();
proximitySensor.powerOnAmbient();
proximitySensor.enableWhiteChannel();
digitalWrite(pinCONTROL,LOW);
digitalWrite(CLOCK, LOW);
digitalWrite(LATCH, LOW);
analogWrite(OE, 240);
digitalWrite(DATA, LOW);
if(48 == MyAddress[0] && 49 == MyAddress[1]){
ambientValue = proximitySensor.getAmbient();
VAL = map(ambientValue,0,65535,0,240);
if(VAL > 240){
VAL = 240;
}else if(VAL < 0){
VAL = 0;
VAL = 240 - VAL; //REVERSE
if(VAL==0 || VAL < 0){ //once
buf[0] = 48;
buf[1] = 48;
buf[2] = 48;
}else if(VAL > 0 && VAL < 10){ //once
dtostrf(VAL, 1, 0, &buf[2]);
buf[0] = 48;
buf[1] = 48;
}else if(VAL > 9 && VAL < 100){ //tens
dtostrf(VAL, 2, 0, &buf[1]);
buf[0] = 48;
}else if(VAL > 99 && VAL < 256){
dtostrf(VAL, 2, 0, &buf[0]);
if(buf[0] == eep.read(50) && buf[1] == eep.read(51) && buf[2] == eep.read(52)){
else{
eep.write(50, buf[0]);delay(15);
eep.write(51, buf[1]);delay(15);
eep.write(52, buf[2]);delay(15);
sendACK(60,80,66,84,MyAddress[0],MyAddress[1], buf[0], buf[1], buf[2], buf[3], 66,62);
if(Serial.available()){
//Serial.println("SR");
while (Serial.available() > 0){
//Serial.println("WHILE : ");
byte_receive=Serial.read();
//Serial.print(byte_receive);
if(byte_receive == 40){ //if first byte is <
state=1;
cont=1;
//Serial.println("40");
} else if (state==1 && cont<12){ // if second byte received then save rest bytes in another array
data[cont-1] = byte_receive;
state=1;
cont=cont+1;
if(cont==12){
cont=1;
state=0;
if(data[0] == 67 && data[1] == 83 && data[9] == 89 && data[10] == 41)
//Serial.println("TRUE COMMAND");
if(data[2] == MyAddress[0] && data[3] == MyAddress[1]){
eep.write(0, data[4]);delay(10);
eep.write(1, data[5]);delay(10);
eep.write(2, data[6]);delay(10);
eep.write(3, data[7]);delay(10);
eep.write(4, data[8]);delay(10);
sendACK(60,80,75,data[2],data[3], data[4], data[5], data[6], data[7], data[8], 66,62);
Show_Price();
else if(data[0] == 67 && data[1] == 77 && data[9] == 89 && data[10] == 41)
print_message(MODULE_ID);
delay(5000);
Show_Price();
else if(data[0] == 67 && data[1] == 66 && data[9] == 89 && data[10] == 41)
temps[0] = data[5];
temps[1] = data[6];
temps[2] = data[7];
temps[3] = data[8];
temps[4] = NULL;
brightness = (int)strtod(temps, NULL);
analogWrite(OE, brightness);
else if(data[0] == 67 && data[1] == 69 && data[9] == 89 && data[10] == 41)
sendACK(60,80,80,MyAddress[0],MyAddress[1], 48, 48, 48, 48, 48, 66,62);
