Hi, i'm currently involved in a project that includes storing data on a stick through a VDIP1 Vinculum module. I'm using a Arduino Mega2560. I hooked up the VDIP1 pins to Arduino Serial1 pins. Tx-Rx and Rx-Tx and I tied up VDIP1 CTS and RTS together. The problem is that, when i'm trying something simple like creating/opening a file on the stick, nothing happens. I tried debbuging this using a led from my Arduino shield, to show me if the file is created, but it seems that Serial1 is never available therefore the LED never blinks. Any ideas for solving this? It's my first project on Arduino and i really suck on this platform. Code attached below. Any help would be greatly appreciated.
Thanx for your replay Nick.You're right, the Seral1.available from my code is useless. That's for reading incoming byte. All i want is to open a file and then close it. I assume that this is your code, Arduino Playground - UsbMemory, so i used it, with Serial1 instead. The problem is that it still doesn't work. It seems that this operation is pretty straightforward, but i don't know were i'm doing wrong. Related to specs, what specs do you need?
You may know what that is, and thousands of others might, but I'm not one of them. If you are posting about a sketch involving it helps to post a link to the exact gadget.
Ok, sorry i thought that you were already familiarized with this device because there was a Nick on that page. So the link for this device is http://www.comet.srl.ro/comet/new/FTDI/DS_VDIP1.pdf. The module communicates with arduino board through AD0(TX) and AD1(RX)pins, which are connected to the arduino Serial1 port. The module also have two pins that are used for flow control AD2 (RTS) and AD3(CTS) and these pins are tied together with a wire.The device is also connected to the arduino 5V and GND. I'm using UART communication. This is the configuration and i've verified twice if i hooked up the wires correctly.Everything looks allright, but still, the file refuses to show up on the stick when i try to create it. Thanks.
You have a USB memory stick plugged into it? I just use SD cards these days plugged into an SD reader, a bit simpler than sending serial commands to some intermediate device.
Yes, there is a USB stick into it. It wasn't actually my choice to work with this module, so i have to stick with it and make a datalogger as soon as possible. If i manage to create/close a file on the stick, then everything should be easy. But as simple as it looks like, this module seems to cause problems to its users.
Thank you anyway. The commands that i'm using are standard for opening/closing files on the stick. Is there any method on Arduino to open Serial1, like I'm doing with the standard Serial Monitor, and see if something is happening there?
Serial goes through the USB interface. Serial1 doesn't. But if you get an FTDI cable (around $20) and hook it up with Tx/Rx connected to the Serial1 Tx/Rx (whichever way around it is) then you should be able to monitor the Serial1 output that way.
