So I've finally figured out my big snafu with the vdip1 and I'm able to log to it. I haven't been able to figure out using cts rts yet but that will be another post.
If I run this code:
#include <AFSoftSerial.h>
int incomingByte=0;
int fileNumber=1;
int noOfChars;
long int valToWrite;
char activityToLog;
long int x;
long int startLogTime = 0;
#define rxPin 2
#define txPin 3
AFSoftSerial vSerial = AFSoftSerial(rxPin, txPin);
vSerial.begin(9600); // opens serial port, sets data rate to 9600 bps
vSerial.print("IPA"); // sets the vdip to use ascii numbers (so I can read them in the code easily!)
vSerial.print(13, BYTE); // return character to tell vdip its end of message
delay(10000); //10 seconds to init the disk before writing (some disks may take longer)
vSerial.print("OPW LOG%"); // open to write creates a file - named
vSerial.print(fileNumber); // LOG%1.TXT first time round - .TXT is for the computer
vSerial.print(".TXT"); // I have used the % sign in the name so I can search the disk for log files that it has created so as not to overwrite any that may be on already
vSerial.print("WRF "); //write to file (file needs to have been opened to write first)
vSerial.print(6); //needs to then be told how many characters will be written
vSerial.print(13, BYTE); //return to say command is finished
vSerial.print("123456"); //followed by the info to write
vSerial.print(13, BYTE); //write a return to the contents of the file (so each entry appears on a new line)
vSerial.print("CLF LOG%"); // it closes the file
// fileNumber++; //so we can create other files
delay(10000);
get_file_num();
void get_file_num(){
vSerial.print("DIR");
delay(1000); //wait a second
while (char i = vSerial.read()){ //umlauted ÿ should be check character...ie hex 98 or dec 152
Serial.print(i); //debug to serial monitor on IDE
if (i == '%'){
fileNumber = vSerial.read() + 1; //should work, but might have to convert to int and back
/*if (i == 'D'){ //if we get a D that isn't a D:\ then exit because that is the last log#
if (vSerial.read() != ':'){
if (vSerial.read() != '\\'){
return;
delay(10000);
I get this output (via the serial monitor on the ide):
D:>
D:>
D:>
D:>
D:>
DISK.
TRASHE~1 DIR
_~1.TRA
LOG%.TXT
Dÿÿÿÿ
The 'ÿ' repeats indefinitely. I attempted to use this character as the test for the end of the file listing, but that didn't work and I got the same output via the serial monitor. Perhaps I need to test for something else.
I could always store a file count in the eeprom, but that is problematic for several reasons (I'm almost out of sketch space and adding a lib doesn't help, plus I'm not sure I want to wear out the EEPROM so fast).
I am also contemplating storing a file number in a file called "f" and using that for file counts. I'm kind of afraid of the overhead of this transaction though.
In addition I'm not sure that doing a DIR will show the log files in numerical order. So I might not be looking for the last file listed with "%" in it.
I'm running the alt software serial lib because I intend to integrate this into a project that uses an lcd. I am open to switching the LCD to software serial though.
PS:
This should work but doesn't. Can someone please explain why?
if (i == '%'){
if (i == 'ÿ'){
return;
The Serial.print(i) returns this:
D:\>
DISK.
TRASHE~1 DIR
_~1.TRA
DS_STO~1.
_LOG%~1.TXT
LOG%.TXÿÿÿÿÿ
