Hej,
I just wanted to share my code, as i could not find any on the web, on how to get data from a VDO oil pressure sender.
1200ohm - 5v - arduino - VDO oil pressure sender
Arduino is connected to the sender like this:
5v -- 1200ohm ---|----- VDO sender ----- GND
A0 --------------|
Raw values is mesuured with a ANALOG gauge. To be more precise.. USE A DIGITAL PRESSURE GAUGE
67 = 0bar
145 = 1bar
235 = 2bar
248 = 2,2bar
288 = 3bar
352 = 4bar
386 = 5bar
441 = 6bar
475 = 7bar
PLease note.. the VDO signal i NOT LINEAR, this is why i made it like this... to compensate for the unlinear signal.
Link to VDO signal curve: https://support.wellandpower.net/hc/en-us/articles/360002119317-How-do-you-test-an-oil-pressue-sender-
const int analogInPin = A0; // Analog input pin
int sensorValue = 0; // value read from the pot
int outputValue = 0; // value output
float output = 0; // Final decimal output.
int stat = 101; // Debug var.
// initialize serial communications at 9600 bps:
sensorValue = analogRead(analogInPin); // Get RAW value from VDO
switch (sensorValue) {
case 0 ... 66: // 3 - 4bar
stat = 0;
output = 0;
case 67 ... 145: // 0 - 1bar
stat = 1;
sensorValue = map(sensorValue, 67, 145, 10, 31);
outputValue = map(sensorValue, 10, 31, 0, 100);
output = (float(outputValue) / 100);
case 146 ... 235: // 1 - 2bar
stat = 2;
sensorValue = map(sensorValue, 146, 235, 31, 52);
outputValue = map(sensorValue, 31, 52, 100, 200);
case 236 ... 248: // 2 - 2,2bar
stat = 3;
sensorValue = map(sensorValue, 236, 248, 52, 66);
outputValue = map(sensorValue, 52, 66, 100, 120);
output = (float((outputValue + 100)) / 100);
case 249 ... 288: // 2,2 - 3bar
stat = 4;
sensorValue = map(sensorValue, 249, 288, 66, 71);
outputValue = map(sensorValue, 66, 71, 220, 300);
case 289 ... 352: // 3 - 4bar
stat = 5;
sensorValue = map(sensorValue, 289, 352, 71, 90);
outputValue = map(sensorValue, 71, 90, 300, 400);
case 353 ... 386: // 4 - 5bar
stat = 6;
sensorValue = map(sensorValue, 353, 386, 90, 107);
outputValue = map(sensorValue, 90, 107, 400, 500);
case 387 ... 441: // 5 - 6bar
stat = 7;
sensorValue = map(sensorValue, 387, 441, 107, 124);
outputValue = map(sensorValue, 107, 124, 500, 600);
case 442 ... 457: // 6 - 7bar
stat = 8;
sensorValue = map(sensorValue, 442, 475, 124, 140);
outputValue = map(sensorValue, 124, 140, 600, 700);
// print the results to the Serial Monitor:
Serial.print("sensor = ");
Serial.print(analogRead(analogInPin));
Serial.print("\t stat = ");
Serial.print(stat);
Serial.print("\t lol = ");
Serial.print(outputValue);
Serial.print("\t output = ");
Serial.println(output);
delay(100);
