Vector
Hello,
iI just learned that vector.h is not part of the avrg++ library.
So what do i do, when i need to use a "dynamic" array then?
Don't. That is not a good idea with 2K of RAM.
KeithRB:
hmm. so then what's the general approach on the situations where you don't know the size of the array?
AZZ:
Allocate the maximum size that you can tolerate at compile time and only use what you need. Use a variable to specify the size instead of sizeof().
aarg:
i feel i'm going to be laughed at, but still i'll try:
why not to sizeof() ? sizeof operator - cppreference.com looks legit to me.
It is legit but not for this purpose. You need to know how much you have used, not what the maximum size is - you should already know the maximum size.
However, do NOT exceed the size of your Arduino's memory!
By the way, that was a valid question and I am not laughing.
vaj4088:
so i do need to learn the old style memalloc/free workflows to be able to work with the boards?
No; it's because malloc/free doesn't work well in low-memory systems that you need to avoid high-level containers like C++ vectors in the first place. You have to go back even further:
static const MAXPOINTS = 50;         // maximum number of points allowed
point_type mypoints[MAXPOINTS];  // static storage for all of them
int current_points = 0;       // how many points actually have been added
void add_point(point_type point)
   mypoints[current_points] = point;
   current_point += 1;
(ok, maybe not THAT far back; you can wrap a nice C++ object around things. But the idea is to avoid any dynamic allocation of memory at all.)
westfw:
  current_point += 1;
westfw:
  current_point += 1;
got it . thank you!
