Vehicle remote ignition - Some questions.
Check whether your engine will cold start reliably on a closed throttle - some engines won't. Also, some engines need a little throttle after they've started to pick the revs up high enough for the alternator to kick in. Depending on the engine and what type of idle speed control it has this may all work fine, but it's the sort of thing that could be a real problem on an older engine.
