I use an:
- 01 HC-SR04 ultrasonic sensor
- 02 Infrared sensor avoids obstacles
- 01 module bluetooth HC-05
- 01 mudule infrared control
I want to control simultaneously bluetooth and infrared automatic when driving, so how? I need help people's! sincerely thanks!
I wrote the code below:
#include <AFMotor.h>
#include <NewPing.h>
#include <Servo.h>
#define TRIG_PIN A0
#define ECHO_PIN A1
#define RS A3
#define LS A4
#define MAX_DISTANCE 200
NewPing sonar(TRIG_PIN, ECHO_PIN, MAX_DISTANCE);
Servo myservo;
AF_DCMotor motor1(1);
AF_DCMotor motor2(2);
AF_DCMotor motor3(3);
AF_DCMotor motor4(4);
boolean goesForward=false;
int distance = 100;
int speedSet = 0;
pinMode(RS, INPUT);
pinMode(RS, INPUT);
myservo.attach(9);
myservo.write(80);
delay(2000);
distance = readPing();
delay(100);
delay(100);
delay(100);
delay(100);
int distanceR = 0;
int distanceL = 0;
delay(40);
if(distance<=30)
moveStop();
moveBackward();
delay(200);
moveStop();
delay(100);
distanceR = lookRight();
delay(100);
distanceL = lookLeft();
delay(100);
if(distanceR>=distanceL)
turnRight();
moveStop();
}else
turnLeft();
moveStop();
}else
moveForward();
if(digitalRead(LS) && !(digitalRead(RS)))
motor1.run(FORWARD); motor1.setSpeed(255);
motor2.run(BACKWARD); motor2.setSpeed(255);
motor3.run(BACKWARD); motor3.setSpeed(255);
motor4.run(FORWARD); motor4.setSpeed(255);
delay(100);
moveForward();
if(!(digitalRead(LS)) && digitalRead(RS))
motor1.run(BACKWARD);
motor2.run(FORWARD);
motor3.run(FORWARD);
motor4.run(BACKWARD);
delay(100);
moveForward();
int lookRight()
myservo.write(30);
delay(400);
int distance = readPing();
delay(100);
myservo.write(80);
return distance;
int lookLeft()
myservo.write(150);
delay(400);
delay(100);
myservo.write(80);
return distance;
delay(100);
int readPing() {
delay(70);
int cm = sonar.ping_cm();
if(cm==0)
cm = 250;
return cm;
void moveStop() {
motor1.run(RELEASE); motor1.setSpeed(0);
motor2.run(RELEASE); motor2.setSpeed(0);
motor3.run(RELEASE); motor3.setSpeed(0);
motor4.run(RELEASE); motor4.setSpeed(0);
void moveForward() {
motor2.run(FORWARD); motor2.setSpeed(255);
motor3.run(FORWARD); motor3.setSpeed(255);
void moveBackward() {
motor1.run(BACKWARD); motor1.setSpeed(255);
motor4.run(BACKWARD); motor4.setSpeed(255);
void turnRight() {
motor3.run(FORWARD); motor3.setSpeed(220);
delay(300);
moveForward();
void turnLeft() {
delay(300);
moveForward();
