Vending Machine Relay Cards
Hi Community,
I have found a lot of relay cards from vending machines and I try to use that with an arduino. What I know is that the boards using 5 Volt for the IC’s and 26 Volt for the thyristor’s. The connector has 26 pins (1-9 = Data; 14, 16, 18, 20 = Select(Clock); 12 = Output Enable) and this pins are inverted (with an MC74HC14A) and then they are connected to an MC74HC574A. But I don’t know which voltages I must use and how I can connect this to an Ardunino.
I tried already to send with an K8055 data to it but it won’t work.
→ Set Data Bits
→ Clk (Sel 0)
→ Clear Data Bits
→ Set Data Bits
→ Clk (Sel 1)
→ Clear Data Bits
→ OE
I have attached some images from the board. (or use this link http://fs5.directupload.net/images/160913/7zbcbbb8.jpg and https://s22.postimg.io/7xgo8gie9/WP_20160913_002.jpg)
Best regards
Icronace
Try the sequence
~OE = Low (pull to GND) CLK = LOW Set Data Bits CLK = HIGH CLK = LOW
The ~OE pin will disable all outputs if it's high.
~OE = Low (pull to GND) Set Data Bits CLK = LOW delay where .... CLK = HIGH CLK = LOW
