Vendo todo mi material de Arduino
Buenas, en primer lugar no se si este post va aquí, si no es así pido disculpas. Como dice el título del post vendo todo lo que tengo, vale nuevo unos 170€, lo dejo en 85 con gastos de envío incluido, soy de Sevilla para posibles tratos en mano.
Listado:
510~520nm 800~1000MCD 5mm LED - Green (100-Piece Pack) 635~645nm 800~1000MCD 5mm LED - Red (100-Piece Pack) OV7670 300KP VGA Camera Module for Arduino Infrared IR Line Finder Sensor Module for Arduino XS056 1.8" TFT Module for Arduino / AVR / PIC / C51 10PF 50V Leaded Multilayer Ceramic Capacitor - Yellow (210-Piece Pack) Serial Bluetooth RF Transmission Module for Arduino S3003 38G Mini Copper + PCB + Plastic Gear Steering Servo - Black (4.8V) L298N Motor Shield V1.0 Expansion Board - White 2WD Robot Car Chassis 2 Motors Magician Robotics Platform for Arduino Keyes 5V Relay Module for Arduino 28YBT-48 Stepper Motor with ULN2003 Driver (DC 5V) Meeeno Infrared Transmitter Brick for Arduino - Orange Infrared Obstacle Avoidance Detection Photoelectric Sensor for Arduino Keyes Thumb Joystick Module for Arduino Meeeno Mercury Switch Sensor Brick for Arduino 13mm x 2mm Piezo Buzzers - Black (DC 9V / 5-Pack) Keyes Microphone Sound Detection Sensor Module for Arduino Breadboard Jumper Wires for Electronic DIY (65-Cable Pack) 6 x AA Batteries Holder with DC2.1 Power Jack for Arduino HC-SR04 Ultrasonic Sensor Distance Measuring Module Single Port Female to Female Jumper Wire Set (50-Pack/20CM-Length) Mini 8 x 8 Red LED Display Common Cathode Dot Matrix Module - Black + White (2 PCS) S3003 38G Mini Copper + PCB + Plastic Gear Steering Servo - Black (4.8V) X1301 Uno R3 Starter Singlechip Set Kit - Multicolored LCD Keypad Shield for Arduino Duemilanove & LCD 1602 8X Seven Segments Display + 8X Key + 8X Double Color LED Module for Arduino Light Sensor Photoresistor Module for Arduino DHT11 Digital Temperature Humidity Sensor Module for Arduino 30 chips SN74HC595N
Todo está comprado en dx.com menos los chips 74HC595, podeis buscar el productos para ver si contenido e imágenes allí, sobre todo la del starter pack de arduino, mando fotos por whatsapp tambien al que quiera.
Consulta, cuanto pesa? Y de que volumen hablas. Vivo en Argentina y solo quiero evaluar posible costo de ingreso.
Es un buen lote de elementos, me interesan tambien.
tienes fotos de todo eso junto? quiero ver que tanto bulto hace
yo pregunte primero, jajaja
lol. Esto se va a convertir en subasta. queremos fotos para empezar a ofertar! ya veremos si vale la pena.
Yo espero las imagenes
Sois como tiburones oliendo sangre fresca, jajajaja
Me parece que no habrá subasta. No ha vuelte quien posteo el mensaje.
llegue tarde veo .... Pero seguro que los regalo o se los tiro la patrona y no volvio a escribir jejejeje
NO llegaste tarde porque quien puso el aviso, se fue de paseo.
jejejeje Le estas siguiendo el rastro Surbyte ..... jejejeje ..... por si te interesa hay una gente que tiene un equipo completo del PLC, si no mal recuerdo Siemens ..... Con modulos analogicos, digitales, trsmision de datos, y por lo que tengo entendido los vende varato, por que entro a trabajar a una empresa grande y se deshace de todo ...
Surbyte: que le pusiste un GPS al hombre? ...
