verifica modifica sketch
ciao a tutti.
modificare il seguente sketch
// Include the BMC_SBUS library
#include "BMC_SBUS.h"
//Declare BMC_SBUS Object
BMC_SBUS mySBUS;
//Include Wiichuck Library
#include <WiiChuck.h>
//Declare Wiichuck Object
Nunchuck nunchuck;
// Sbus delay value
const int sbusWAIT        = 7;      //frame timing delay in msecs
// Declare sbus control channels
int panChannel = 1;
int tiltChannel = 2;
int rollChannel = 4;
  // Start Wiichuck Object
  nunchuck.begin();
  // Start BMC_SBUS object
  mySBUS.begin();
    nunchuck.readData();    // Read inputs from wiichuck
    // Get wiichuck data
    int Yvalue = nunchuck.getJoyY();
    int Xvalue = nunchuck.getJoyX();
    int Zbutton = nunchuck.getButtonZ();
    //Map wiichuck values which go from 0-255 to Sbus values 0-2047
    // For no move send 1023
    int sendValueY = map(Yvalue,0,255,0,2047);
    int sendValueX = map(Xvalue,0,255,0,2047);
    // Set sbus tilt
    mySBUS.Servo(tiltChannel,sendValueY);
    // Check if trigger(button Z) is pressed, if so send the X value to roll channel
    if (Zbutton == 1) {
       mySBUS.Servo(rollChannel,sendValueX);
       mySBUS.Servo(panChannel,sendValueX);
    // Update SBUS object and send data
    mySBUS.Update();
    mySBUS.Send();
    // Delay for SBUS
    delay(sbusWAIT);
Vorrei poter inviare gli stessi comandi di output non con il dispositivo di input "Wiichuck" (che è un joystick proprietario) ma con un normale joystick analogico a 2 assi X,Y (più il pulsante integrato Z).
Ho modificato il codice in questo modo:
BMC_SBUS mySBUS;
Nunchuck nunchuck;
// Sbus delay value
//********************************************** modifica **********************************************
#define X_pin A0
#define Y_pin A1
#define SW_pin 8
//********************************************** fine modifica **********************************************
int panChannel = 1;
pinMode(SW_pin, INPUT_PULLUP);
  nunchuck.begin();
  mySBUS.begin();
//    nunchuck.readData();    // Read inputs from wiichuck
int Xvalue = analogRead(X_pin);
int Yvalue = analogRead(Y_pin);
int Zbutton = !digitalRead(Zbutton);  //premendo il pulsante il valore è HIGH
    int sendValueY = map(Yvalue,0,1023,0,2047);
    int sendValueX = map(Xvalue,0,1023,0,2047);
    // Set sbus tilt
    if (Zbutton == 1) {
    mySBUS.Update();
    mySBUS.Send();
    // Delay for SBUS
    delay(sbusWAIT);
Dite che può funzionare?
