I'm having a similar issue to this post:
http://forum.arduino.cc/index.php?topic=275446.0
Except I get a different address error and the solution posted there did not work for me.
I get the following error when uploading a sketch:
Sketch uses 24,850 bytes (86%) of program storage space. Maximum is 28,672 bytes.
Global variables use 1,161 bytes (45%) of dynamic memory, leaving 1,399 bytes for local variables. Maximum is 2,560 bytes.
avrdude: Version 5.11svn, compiled on Nov 13 2014 at 21:46:47
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "/etc/avrdude.conf"
User configuration file is "/root/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : unknown
Using Programmer : linuxgpio
AVR Part : ATmega32U4
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 10 8 0 no 1024 8 0 9000 9000 0x00 0x00
flash 65 6 128 0 yes 32768 128 256 4500 4500 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : linuxgpio
Description : Use the Linux sysfs interface to bitbang GPIO lines
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e9587
avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed
To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: reading input file "0xFF"
avrdude: writing lfuse (1 bytes):
Writing | ################################################## | 100% 0.00s
avrdude: 1 bytes of lfuse written
avrdude: verifying lfuse memory against 0xFF:
avrdude: load data lfuse data from input file 0xFF:
avrdude: input file 0xFF contains 1 bytes
avrdude: reading on-chip lfuse data:
avrdude: verifying ...
avrdude: 1 bytes of lfuse verified
avrdude: reading input file "0xD8"
avrdude: writing hfuse (1 bytes):
avrdude: 1 bytes of hfuse written
avrdude: verifying hfuse memory against 0xD8:
avrdude: load data hfuse data from input file 0xD8:
avrdude: input file 0xD8 contains 1 bytes
avrdude: reading on-chip hfuse data:
avrdude: 1 bytes of hfuse verified
avrdude: reading input file "0xFB"
avrdude: writing efuse (1 bytes):
avrdude: 1 bytes of efuse written
avrdude: verifying efuse memory against 0xFB:
avrdude: load data efuse data from input file 0xFB:
avrdude: input file 0xFB contains 1 bytes
avrdude: reading on-chip efuse data:
Reading | ################################################## | 100% 0.01s
avrdude: 1 bytes of efuse verified
avrdude: reading input file "/tmp/sketch.hex"
avrdude: writing flash (32748 bytes):
Writing | ################################################## | 100% 16.41s
avrdude: 32748 bytes of flash written
avrdude: verifying flash memory against /tmp/sketch.hex:
avrdude: load data flash data from input file /tmp/sketch.hex:
avrdude: input file /tmp/sketch.hex contains 32748 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 15.13s
avrdude: [b]verification error, first mismatch at byte 0x0080[/b]
[b]0xff != 0x0c[/b]
avrdude: verification error; content mismatch
avrdude done. Thank you.
This board has been working for a couple months with weekly/daily updates as the sketch is evolved. Today I was working on a shell script that was being called by the sketch and now I can't get rid of the above error. I've search all over google and many people seem to have a similar error at byte 0x0000. I found one post that said to check if the file usr/bin/run-avrdude showed something different than "efuse:w:0xFB" (based on this bug: run-avrdude sets efuse · Issue #12 · arduino/openwrt-yun · GitHub). I did change one of the efuse values to "FB" but it didn't help me. My run-avrdude is:
#!/bin/sh
echo 1 > /sys/class/gpio/gpio21/value
avrdude -q -q -c linuxgpio -C /etc/avrdude.conf -p m32u4 -U efuse:r:/tmp/efuse:d
read EFUSE < /tmp/efuse
rm -f /tmp/efuse
if [ "x$EFUSE" = "x203" ] # 203 = 0xCB
then
avrdude -c linuxgpio -C /etc/avrdude.conf -p m32u4 -U lfuse:w:0xFF:m -U hfuse:w:0xD8:m -U efuse:w:0xFB:m -Uflash:w:$1:i $2
fi
echo 0 > /sys/class/gpio/gpio21/value
I'm stuck with a board that doesn't work and I would love some help. I can access the linux side of the Yun via winSCP and have reset the board through the webpage. But this seems like something that a reset won't fix. I've also tried uploading a simple blinking example sketch with the same error as the result. I also tried reflashing the YunSystemUpgrade image 1.5.3 but that didn't change anything. I also don't get any connection from the Console just the 'usual' can't connect to the bridge error.
Thanks for any ideas
