verified function crashes when included in another sketch
A verified sketch contains a “void XXXXXXXXXXXX()” function. I mean verified about this is IN a working sketch.
Well, I take this working sketch, add a couple of whiles and if/else lines and then, voilá, “function-definition is not allowed here before ‘{’ token” and this “void XXXXXXXXXXXX()” begins to screw everything¡
The code is quite long, but i can upload if it can help.
I tryed to paste this function in a separate ino file and include it through #include <blablabla.ino> but it doesn’t find it in the folder.
has anybody experienced something similar?
Could any body help me with this question, please?
Sounds like you’ve got your curly braces messed up. If you post the code we might be able to help. If you don’t want to post it, then you’ll have to go through and count braces yourself.
If you use control - t to autoformat the code it will line things up and maybe make it easier to see.
Usually and messy, haphazard copy and paste is the issue. Clean, tab, and organize your code.
Thanks¡
that's what i suspected. i counted many times, and carefuly, the brackets and everything seems to be ok.
I inserted the working code directly where noted below, i put the global variables in it's right place and so on:
boolean state = false
int buttonPin=8;
int redLed=9;
int greenLed=10;
void setup(){
  pinMode(redLed,OUTPUT);
  pinMode(greenLed,OUTPUT);
 while (state == false)
   if (digitalRead(buttonPin) == HIGH)
      state = true;
      analogWrite(redLed, 255);
 while (state == true)
      state = false;
     analogWrite(greenLed, 255);
   [b]CODE AHRS HERE¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡[u][/u][/b] (just the loop part here)
once i notice it didn't work I tryed other combinations but same result.
The part that is making the error is a function defined after the void loop() closing bracket and look like this:
void MadgwickQuaternionUpdate(float ax, float ay, float az, float gx, float gy, float gz, float mx, float my, float mz)
  float q1 = q[0], q2 = q[1], q3 = q[2], q4 = q[3];   // short name local variable for readability
  float norm;
  float hx, hy, _2bx, _2bz;
  float s1, s2, s3, s4;
  float qDot1, qDot2, qDot3, qDot4;
  // Auxiliary variables to avoid repeated arithmetic
  float _2q1mx;
  float _2q1my;
  float _2q1mz;
  float _2q2mx;
  float _4bx;
  float _4bz;
  float _2q1 = 2.0f * q1;
  float _2q2 = 2.0f * q2;
  float _2q3 = 2.0f * q3;
  float _2q4 = 2.0f * q4;
  float _2q1q3 = 2.0f * q1 * q3;
  float _2q3q4 = 2.0f * q3 * q4;
  float q1q1 = q1 * q1;
  float q1q2 = q1 * q2;
  float q1q3 = q1 * q3;
  float q1q4 = q1 * q4;
  float q2q2 = q2 * q2;
  float q2q3 = q2 * q3;
  float q2q4 = q2 * q4;
  float q3q3 = q3 * q3;
  float q3q4 = q3 * q4;
  float q4q4 = q4 * q4;
  // Normalise accelerometer measurement
  norm = sqrt(ax * ax + ay * ay + az * az);
  if (norm == 0.0f) return; // handle NaN
  norm = 1.0f / norm;
  ax *= norm;
  ay *= norm;
  az *= norm;
  // Normalise magnetometer measurement
  norm = sqrt(mx * mx + my * my + mz * mz);
  norm = 1.0f / norm;
  mx *= norm;
  my *= norm;
  mz *= norm;
  // Reference direction of Earth's magnetic field
  _2q1mx = 2.0f * q1 * mx;
  _2q1my = 2.0f * q1 * my;
  _2q1mz = 2.0f * q1 * mz;
  _2q2mx = 2.0f * q2 * mx;
  hx = mx * q1q1 - _2q1my * q4 + _2q1mz * q3 + mx * q2q2 + _2q2 * my * q3 + _2q2 * mz * q4 - mx * q3q3 - mx * q4q4;
  hy = _2q1mx * q4 + my * q1q1 - _2q1mz * q2 + _2q2mx * q3 - my * q2q2 + my * q3q3 + _2q3 * mz * q4 - my * q4q4;
  _2bx = sqrt(hx * hx + hy * hy);
  _2bz = -_2q1mx * q3 + _2q1my * q2 + mz * q1q1 + _2q2mx * q4 - mz * q2q2 + _2q3 * my * q4 - mz * q3q3 + mz * q4q4;
  _4bx = 2.0f * _2bx;
  _4bz = 2.0f * _2bz;
  // Gradient decent algorithm corrective step
  s1 = -_2q3 * (2.0f * q2q4 - _2q1q3 - ax) + _2q2 * (2.0f * q1q2 + _2q3q4 - ay) - _2bz * q3 * (_2bx * (0.5f - q3q3 - q4q4) + _2bz * (q2q4 - q1q3) - mx) + (-_2bx * q4 + _2bz * q2) * (_2bx * (q2q3 - q1q4) + _2bz * (q1q2 + q3q4) - my) + _2bx * q3 * (_2bx * (q1q3 + q2q4) + _2bz * (0.5f - q2q2 - q3q3) - mz);
  s2 = _2q4 * (2.0f * q2q4 - _2q1q3 - ax) + _2q1 * (2.0f * q1q2 + _2q3q4 - ay) - 4.0f * q2 * (1.0f - 2.0f * q2q2 - 2.0f * q3q3 - az) + _2bz * q4 * (_2bx * (0.5f - q3q3 - q4q4) + _2bz * (q2q4 - q1q3) - mx) + (_2bx * q3 + _2bz * q1) * (_2bx * (q2q3 - q1q4) + _2bz * (q1q2 + q3q4) - my) + (_2bx * q4 - _4bz * q2) * (_2bx * (q1q3 + q2q4) + _2bz * (0.5f - q2q2 - q3q3) - mz);
  s3 = -_2q1 * (2.0f * q2q4 - _2q1q3 - ax) + _2q4 * (2.0f * q1q2 + _2q3q4 - ay) - 4.0f * q3 * (1.0f - 2.0f * q2q2 - 2.0f * q3q3 - az) + (-_4bx * q3 - _2bz * q1) * (_2bx * (0.5f - q3q3 - q4q4) + _2bz * (q2q4 - q1q3) - mx) + (_2bx * q2 + _2bz * q4) * (_2bx * (q2q3 - q1q4) + _2bz * (q1q2 + q3q4) - my) + (_2bx * q1 - _4bz * q3) * (_2bx * (q1q3 + q2q4) + _2bz * (0.5f - q2q2 - q3q3) - mz);
  s4 = _2q2 * (2.0f * q2q4 - _2q1q3 - ax) + _2q3 * (2.0f * q1q2 + _2q3q4 - ay) + (-_4bx * q4 + _2bz * q2) * (_2bx * (0.5f - q3q3 - q4q4) + _2bz * (q2q4 - q1q3) - mx) + (-_2bx * q1 + _2bz * q3) * (_2bx * (q2q3 - q1q4) + _2bz * (q1q2 + q3q4) - my) + _2bx * q2 * (_2bx * (q1q3 + q2q4) + _2bz * (0.5f - q2q2 - q3q3) - mz);
  norm = sqrt(s1 * s1 + s2 * s2 + s3 * s3 + s4 * s4);    // normalise step magnitude
  norm = 1.0f / norm;
  s1 *= norm;
  s2 *= norm;
  s3 *= norm;
  s4 *= norm;
  // Compute rate of change of quaternion
  qDot1 = 0.5f * (-q2 * gx - q3 * gy - q4 * gz) - beta * s1;
  qDot2 = 0.5f * (q1 * gx + q3 * gz - q4 * gy) - beta * s2;
  qDot3 = 0.5f * (q1 * gy - q2 * gz + q4 * gx) - beta * s3;
  qDot4 = 0.5f * (q1 * gz + q2 * gy - q3 * gx) - beta * s4;
  // Integrate to yield quaternion
  q1 += qDot1 * deltat;
  q2 += qDot2 * deltat;
  q3 += qDot3 * deltat;
  q4 += qDot4 * deltat;
  norm = sqrt(q1 * q1 + q2 * q2 + q3 * q3 + q4 * q4);    // normalise quaternion
  norm = 1.0f / norm;
  q[0] = q1 * norm;
  q[1] = q2 * norm;
  q[2] = q3 * norm;
  q[3] = q4 * norm;
as you can see there is only an open and a close bracket here so little room for this kind of error...
so that why i thought about calling this function from outside the main sketch...
SORRY DUDES for that long issue and THANKS AGAIN¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡
In the first code in replay #3, there is no closing brace for setup function. So loop appears to be defined inside setup which is an error.
Double clicking after an opening or closing brace is a good way to see the code block associated with the brace.
Hi delta_G, i noticed and correct it previously, thanks¡
UKHeliBob, Didn't know this double click trick....solved, missing } knew that positioning the cursor it highlighted the analog bracket, but this way missed the count........really useful¡¡
thanks you all where right from the very beginning and i was....impatient :-[ two days counting brackets for nothing¡¡¡
thanks again¡¡
