i made a program to read multiple hard drive style encoders using digitalRead, but someone reccomneded to use direct pin manipulation ast it would be faster. here are some excerpts of the code that i want to make sure im doing right, could someone look over it quick?
//goes from left to right
// 76543210
DDRD = B00000000; //sets 2 through 7 as inputs, RX and TX stay as inputs
PORTD &= B11111100; //enable pullups on all but tx/rx pins
// ..13...8
DDRB &= B11000000; //sets through 13 as inputs excpet for crystal pins
PORTB &= B00111111; //enable pullups on all but crystal pins
// ..543210
DDRC = B00000000; //sets analog 0 through 5 as inputs
PORTC &= B00111111; //enable pullups on all but analog 6 an 7 (6 and 7 arent avaliable on atmega 328)
// 76543210
//(PIND & B00001000) check only the pin '1' (in this case digital 3) in this line for low or high, & means dont check any others
//would be the same as: PIND & (1 << 3);
if ((PIND & B00001000) == 1) //check state of digital pin 3, if it is HIGH
if ((PIND & B00001000) == 0) //check state of digital pin 3, if it is LOW
also, which would be faster:
or
if ((PIND & (1 << 3)) == 1) //check state of digital pin 3, if it is HIGH
// 76543210
The value of (PIND & B00001000) will be B00001000 (true) if bit 3 of PIND is set, and B00000000 (false) if it is not - and yes, the two representations are equivalent. There is a reasonable probability that the compiler will replace the shift expression with a logical value no matter how you code it.
No, if pin 3 is high the value of the expression will be 8 (true) which will not == 1
Yes.
If the compiler were brain-dead, the first example would be faster (but wrong) because it starts with a value that the second example would waste time constructing with a shift - but gcc isn't in the brain-dead catagory, so I'd be willing to bet a cup of coffee that both examples will compile to the exact same code.
Note that it's not necessary to compare the result of the AND to 1. Anything non-zero will be true, and only a zero result will be false.
Late night brain fart - which was immediately corrected with an edit. If you need an apology from me for that, consider it offered. I'll be more careful in the future...
