Verifying program code
Can someone verify if the code below is correct? Setup is Arduino uno R3 connected to stepper motor which is controlled by a push button and plays a single .mp3 file from an .mp3 card
The goal is to press the push button, have the stepper motor spin + play the .mp3 file at the same time at which point 10 seconds later everything ends. The button would be required to be pressed (not held) once in order to repeat the process. Thanks in advance
const int buttonPin = 2;     // the number of the pushbutton pin
// variables will change:
int buttonState = 0;         // variable for reading the pushbutton status
  // initialize the pushbutton pin as an input:
  pinMode(buttonPin, INPUT);
  // read the state of the pushbutton value:
  buttonState = digitalRead(buttonPin);
  // check if the pushbutton is pressed.
  // if it is, the buttonState is HIGH:
  if (buttonState == HIGH) {
    // run the stepper motor function:
    steppermotorfunction();
     delay(50);//do nothing and give some delay just because
void steppermotorfunction() {
//write code for stepper motor cycle here
#include <Stepper.h>
int x = 0;
const int stepsPerRevolution = 200;  // change this to fit the number of steps per revolution
// for your motor
// initialize the stepper library on pins 8 through 11:
Stepper myStepper(stepsPerRevolution, 8, 9, 10, 11);
  // set the speed at 60 rpm:
  myStepper.setSpeed(63);
  // initialize the serial port:
  Serial.begin(4800);
if (x <= 10)
{ // step one revolution in one direction:
  Serial.println("clockwise");
  myStepper.step(stepsPerRevolution);
  // delay(500);
x++;
  // step one revolution in the other direction:
  // Serial.println("counterclockwise");
// myStepper.step(-stepsPerRevolution);
// delay(500);
  Serial.write(0x01);
If you send me the hardware, I'll upload the code, and tell you whether it does what you say it should.
Also, you have two functions named setup() and loop(), which will not work. Each Arduino program has only one each of these functions in a sketch.
You may be interested in Stepper Motor Basics and in this Simple Stepper Code which may be useful for testing.
…R
