I need some help understanding the changes between ver 19 and ver 20
An application evolved fitting comfortably on a Duemilanove now requires a Mega to accommodate I/O and memory needs. We do need to put some additional soil test instruments in the field this spring using the software and controllers developed last summer. The application from last summer has developed some problems.
It compiles with v19, loads and runs fine on a Duemilnove. It compiles fine and loads with 20, 21 & 22 but hangs almost immediately. It acts about the same on a UNO.
The disassembled files are some different. The immediate obvious difference is that 19 contains the code for malloc, calloc and free. Clearly something significant happened with the move to ver 20. Clearly I can scrounge up enough Duemilnove boards to get by, but not understanding the problem is upsetting. Not being able to use the UNO boards adds to the frustration
the lengths of the hex files are:
ver 19 57 k (works)
ver 22 54 k don't work
ver 22 60 k mega 1280 probably works but the shields are not configure correctly to interact
I would post code but without the right logger and additional circuitry, they all hang. The code works fine with a Due. and ver 19
the includes:
#include <SdFat.h>
#include <SdFatUtil.h>
#include <Wire.h>
#include <RTClib.h>
#include <EEPROM.h>
Any thoughts?
