Have a toy snake to rise out of basket about 8 in. Plan on using fishing line attached to cylinder within cylinder, as line pulled inside cylinder rises (is inside snake). Will a stepper motor be the best for this? Snake weighs less than 8 oz. line attached to spool and will need to unwind the same distance.
Would use linear actuator but that length too pricey.
Will need the servo to turn fairly fast so that snake gets up in 3-5 sec. I suppose if I attach a large spool to the servo would work. Thanks for suggestion
