Vertical Scrolling on TFT LCD
Hey there,
I recently bought a tft LCD from Adafruit and have been trying to get it to scroll down(vertically) for the past week. There is not a ton of documentation on it. I can run the test on the LCD and it displays everything great, however when it runs out of space on LCD it just stops and wont scroll down. I assumed it would be an easy task but it has proven to be quite challenging. I’m fairly new to programming but I feel like this shouldn’t be too difficult. If someone could provide some advice or guidance in the right direction it would be greatly appreciated! Thank you!
#include <LiquidCrystal.h>
// IMPORTANT: Adafruit_TFTLCD LIBRARY MUST BE SPECIFICALLY
// CONFIGURED FOR EITHER THE TFT SHIELD OR THE BREAKOUT BOARD.
// SEE RELEVANT COMMENTS IN Adafruit_TFTLCD.h FOR SETUP.
#include <Adafruit_GFX.h>    // Core graphics library
#include <Adafruit_TFTLCD.h> // Hardware-specific library
// The control pins for the LCD can be assigned to any digital or
// analog pins...but we'll use the analog pins as this allows us to
// double up the pins with the touch screen (see the TFT paint example).
#define LCD_CS A3 // Chip Select goes to Analog 3
#define LCD_CD A2 // Command/Data goes to Analog 2
#define LCD_WR A1 // LCD Write goes to Analog 1
#define LCD_RD A0 // LCD Read goes to Analog 0
#define LCD_RESET A4 // Can alternately just connect to Arduino's reset pin
// When using the BREAKOUT BOARD only, use these 8 data lines to the LCD:
// For the Arduino Uno, Duemilanove, Diecimila, etc.:
//   D0 connects to digital pin 8  (Notice these are
//   D1 connects to digital pin 9   NOT in order!)
//   D2 connects to digital pin 2
//   D3 connects to digital pin 3
//   D4 connects to digital pin 4
//   D5 connects to digital pin 5
//   D6 connects to digital pin 6
//   D7 connects to digital pin 7
// For the Arduino Mega, use digital pins 22 through 29
// (on the 2-row header at the end of the board).
// Assign human-readable names to some common 16-bit color values:
#define BLACK   0x0000
#define BLUE    0x001F
#define RED     0xF800
#define GREEN   0x07E0
#define CYAN    0x07FF
#define MAGENTA 0xF81F
#define YELLOW  0xFFE0
#define WHITE   0xFFFF
#define Vertical       0x52
//LiquidCrystal lcd(12,11,5,4,3,2);
Adafruit_TFTLCD tft(LCD_CS, LCD_CD, LCD_WR, LCD_RD, LCD_RESET);
// If using the shield, all control and data lines are fixed, and
// a simpler declaration can optionally be used:
// Adafruit_TFTLCD tft;
int x[1000] = {0,20,40,60,80,100,120,140,160,180,200,220,240,260,260};
int x2[1000] = {0,20,40,60,80,100,120,140,160,180,200,220,240,260,261};
void setup(void) {
  Serial.println(F("TFT LCD test"));
#ifdef USE_ADAFRUIT_SHIELD_PINOUT
  Serial.println(F("Using Adafruit 2.8\" TFT Arduino Shield Pinout"));
#else
  Serial.println(F("Using Adafruit 2.8\" TFT Breakout Board Pinout"));
#endif
  Serial.print("TFT size is "); Serial.print(tft.width()); Serial.print("x"); Serial.println(tft.height());
  tft.reset();
  uint16_t identifier = tft.readID();
 if(identifier == 0x9341) {
    Serial.println(F("Found ILI9341 LCD driver"));
    Serial.print(F("Unknown LCD driver chip: "));
    Serial.println(identifier, HEX);
    Serial.println(F("If using the Adafruit 2.8\" TFT Arduino shield, the line:"));
    Serial.println(F("  #define USE_ADAFRUIT_SHIELD_PINOUT"));
    Serial.println(F("should appear in the library header (Adafruit_TFT.h)."));
    Serial.println(F("If using the breakout board, it should NOT be #defined!"));
    Serial.println(F("Also if using the breakout, double-check that all wiring"));
    Serial.println(F("matches the tutorial."));
    return;
  tft.begin(identifier);
void loop(void) {
  uint8_t rotation = 0;
  tft.setRotation(rotation);
  tft.fillScreen(BLACK);
   for(uint8_t j =0; j <50; j ++) {
    tft.setCursor(0, x[j]);
    testText();
    tft.println(x2[j]);
    delay(200);
 while("");
char g[1000];
unsigned long testText() {
  unsigned long start = micros();
  tft.setTextColor(WHITE);
   tft.setTextSize(1);
  // tft.println(g);
  tft.print("HELLO THERE");
  tft.write(Vertical);
  return micros() - start;
