Very Basic NeoPixel Ring X16 Spin/Chase Green with Tail
I am very new to Arduino. Mine just arrived yesterday.
I apologize that I do not have any example code to post. I can't find a sufficiently stripped-down existing project to modify. I hope someone here can point me in the right direction. I can use code blocks for certain projects, but there do not appear to be NeoPixel code blocks. I'm not having luck editing published projects.
I don't expect you to sit and write code for me - just maybe some guidance if you're feeling it.
What I hope to achieve, and ultimately incorporate into a larger project, is pretty simple.
  • 5 leading pixels spinning in bright green
  • 3 trailing pixels trailing behind in a dimmer green
  • circle the ring maybe twice a second
Any guidance you can provide would be greatly appreciated. I apologize in advance if I am a jerk.
#define PixelPin 6
#define PixelCount 16
Adafruit_NeoPixel pixels = Adafruit_NeoPixel(PixelCount, PixelPin, NEO_GRB + NEO_KHZ800);
uint32_t colour = 0x00FF00; // Default to Green
int pos = 0;
  pixels.begin();
  pixels.setBrightness(85); // 1/3 brightness
  int start = (millis()%500) * PixelCount / 1000L;   // two rev per second
  for(int i = 0; i<5; i++) {
    pixels.setPixelColor((i+start) % PixelCount, colour);
  for(int i = 5; i<PixelCount; i++) {
    pixels.setPixelColor((i+start) % PixelCount, 0);
  pixels.show();
Adafruit has some good documentaries on the topic.
A neopixle ring is just an array of "colors"
draw the entire array once with your pattern
then every x ms,
save off the end color,
shift all the colors over by one
and stuff the end color into the first position.
-jim lee
