Very Basic Newbie question ANALOG READ
Hi
I am owning a Arduino Uno.
I am reading analog value from 2 pots and would like more stable reading (or less accurate)
then displaying on LCD.
Is there a easy way to divide the result to have less step ? (I understand on the uno I can't change the ADC resolution.)
of course now it give me 1023 step which is way too much in my case (100 steps would be great )
how can I integrate this extra lines in the code below ?
what I the best way to achieve that ?
thanks you so much !
P ;D
9000_TEST.ino (727 Bytes)
If you divide the value returned by analogRead() by 4 or shift it right 2 places, which amounts to the same thing, then the reading will be from 0 to 255.
Is that the sort of thing you had in mind ?
Incidentally, you will get more help if you post your code in the forum like this
// include the library code:
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(7, 8, 9, 10, 11, 12);
int potPin1 = A1;
int potPin2 = A2;
  // set up the LCD's number of columns and rows:
  lcd.begin(16, 2);
  lcd.clear();
  pinMode(potPin1, INPUT);
  pinMode(potPin2, INPUT);
  lcd.setCursor(0, 0); // Sets the cursor to col 0 and row 0
  lcd.print("Line Input 9K: "); // Prints Sensor Val: to LCD
  lcd.print(analogRead(potPin1)); // Prints value on Potpin1 to LCD
  lcd.setCursor(0, 1); // Sets the cursor to col 1 and row 0
  lcd.print("Mic  Input 9k: "); // Prints Sensor Val: to LCD
  lcd.print(analogRead(potPin2)); // Prints value on Potpin1 to LCD
See Read this before posting a programming question
thanks you so much for the advice
will be careful next time I post
could you show me where and how to write it into the code ? (sorry very basic question)
thanks a lot !!
P
  lcd.print(analogRead(potPin1) / 4); // Prints value on Potpin1 to LCD
For completeness you should also update the comments to reflect the pin being read and the change of range
exactly what I needed !
working perfectly !
thank you so much
P
It may also be a good idea to scrap the first reading from each pin in case the ADC still has some residual voltage from the other pin - like this
  int scrap = analogRead(potPin1); // this reading is not used
  scrap = analogRead(potPin2);
...R
The map() function works too:
rawADC = analogRead(potPin1);
newADC = map(rawADC,1023,0,100,0);
There you can choose almost any range, even swap values like 1023 maps to 0 and 0 maps to 100 map(rawADC,1023,0,0,100)
edpsycho:
There you can choose almost any range, even swap values like 1023 maps to 0 and 0 maps to 100 *map(rawADC,1023,0,0,100)*
how would you integrate this to my code ?
tx
p
:astonished:
Ok, first you have to initialize the new vars:
int rawADC = 0;
int newADC = 0;
Then before you print the values on the LCD:
lcd.print(newADC); // Prints value on Potpin1 to LCD
thanks edpsycho !
will try :-))
I have one last question :
what would be the easiest way to display the exact same value as the lcd the serial monitor ?
can't get it to work properly
thanks guy !
P
Just print the same variable to both
