Hi, im very confused because when i compile i get some orange lines in the compile report and tft dont apply tft.setRotation(1); that i have in code, but withot change nothing in code, just pressing again compile, dont get any error and apply corectly tft.setRotation(1);
the orange lines of the report are these
c:\users\migue_000\appdata\local\arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7\avr\include\stdint.h:126:22: note: type 'uint8_t' should match type 'uint16_t'
typedef unsigned int uint8_t __attribute__((__mode__(__QI__)));
c:\users\migue_000\appdata\local\arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7\avr\include\stdint.h:128:22: note: the incompatible type is defined here
typedef unsigned int uint16_t __attribute__ ((__mode__ (__HI__)));
this is the report with some orange lines
C:\arduino-1.8.16\arduino-builder -dump-prefs -logger=machine -hardware C:\arduino-1.8.16\hardware -hardware C:\Users\migue_000\AppData\Local\Arduino15\packages -tools C:\arduino-1.8.16\tools-builder -tools C:\arduino-1.8.16\hardware\tools\avr -tools C:\Users\migue_000\AppData\Local\Arduino15\packages -built-in-libraries C:\arduino-1.8.16\libraries -libraries C:\Users\migue_000\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=2341_0043 -ide-version=10816 -build-path C:\Users\MIGUE_~1\AppData\Local\Temp\arduino_build_650694 -warnings=none -build-cache C:\Users\MIGUE_~1\AppData\Local\Temp\arduino_cache_448091 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Users\migue_000\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\migue_000\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avrdude.path=C:\Users\migue_000\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\migue_000\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.arduinoOTA.path=C:\Users\migue_000\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\migue_000\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -verbose C:\Users\migue_000\Documents\Arduino\Proyectos\sonda10k\sonda10k\sonda10k.ino
C:\arduino-1.8.16\arduino-builder -compile -logger=machine -hardware C:\arduino-1.8.16\hardware -hardware C:\Users\migue_000\AppData\Local\Arduino15\packages -tools C:\arduino-1.8.16\tools-builder -tools C:\arduino-1.8.16\hardware\tools\avr -tools C:\Users\migue_000\AppData\Local\Arduino15\packages -built-in-libraries C:\arduino-1.8.16\libraries -libraries C:\Users\migue_000\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=2341_0043 -ide-version=10816 -build-path C:\Users\MIGUE_~1\AppData\Local\Temp\arduino_build_650694 -warnings=none -build-cache C:\Users\MIGUE_~1\AppData\Local\Temp\arduino_cache_448091 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Users\migue_000\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\migue_000\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avrdude.path=C:\Users\migue_000\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\migue_000\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.arduinoOTA.path=C:\Users\migue_000\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\migue_000\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -verbose C:\Users\migue_000\Documents\Arduino\Proyectos\sonda10k\sonda10k\sonda10k.ino
Using board 'uno' from platform in folder: C:\Users\migue_000\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6
Using core 'arduino' from platform in folder: C:\Users\migue_000\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6
Detecting libraries used...
"C:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10816 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "C:\\Users\\MIGUE_~1\\AppData\\Local\\Temp\\arduino_build_650694\\sketch\\sonda10k.ino.cpp" -o nul
Alternatives for Adafruit_GFX.h: [Adafruit_GFX_Library@1.5.3 Adafruit_GFX_Library-1.10.12@1.10.12 Adafruit_GFX_Library-1.9.0@1.9.0]
ResolveLibrary(Adafruit_GFX.h)
-> candidates: [Adafruit_GFX_Library@1.5.3 Adafruit_GFX_Library-1.10.12@1.10.12 Adafruit_GFX_Library-1.9.0@1.9.0]
"C:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10816 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "C:\\Users\\MIGUE_~1\\AppData\\Local\\Temp\\arduino_build_650694\\sketch\\sonda10k.ino.cpp" -o nul
Alternatives for Adafruit_TFTLCD.h: [Adafruit_TFTLCD_Library@1.0.3]
ResolveLibrary(Adafruit_TFTLCD.h)
-> candidates: [Adafruit_TFTLCD_Library@1.0.3]
"C:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10816 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TFTLCD_Library" "C:\\Users\\MIGUE_~1\\AppData\\Local\\Temp\\arduino_build_650694\\sketch\\sonda10k.ino.cpp" -o nul
Alternatives for TouchScreen.h: [Adafruit_TouchScreen@1.1.2]
ResolveLibrary(TouchScreen.h)
-> candidates: [Adafruit_TouchScreen@1.1.2]
"C:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10816 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TFTLCD_Library" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TouchScreen" "C:\\Users\\MIGUE_~1\\AppData\\Local\\Temp\\arduino_build_650694\\sketch\\sonda10k.ino.cpp" -o nul
Alternatives for EEPROM.h: [EEPROM@2.0]
ResolveLibrary(EEPROM.h)
-> candidates: [EEPROM@2.0]
"C:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10816 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TFTLCD_Library" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TouchScreen" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\EEPROM\\src" "C:\\Users\\MIGUE_~1\\AppData\\Local\\Temp\\arduino_build_650694\\sketch\\sonda10k.ino.cpp" -o nul
Alternatives for ARDESTINE24pt7b.h: [Fonts]
ResolveLibrary(ARDESTINE24pt7b.h)
-> candidates: [Fonts]
"C:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10816 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TFTLCD_Library" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TouchScreen" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\EEPROM\\src" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Fonts" "C:\\Users\\MIGUE_~1\\AppData\\Local\\Temp\\arduino_build_650694\\sketch\\sonda10k.ino.cpp" -o nul
"C:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10816 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TFTLCD_Library" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TouchScreen" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\EEPROM\\src" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Fonts" "C:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library\\Adafruit_GFX.cpp" -o nul
"C:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10816 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TFTLCD_Library" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TouchScreen" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\EEPROM\\src" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Fonts" "C:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library\\Adafruit_SPITFT.cpp" -o nul
Alternatives for SPI.h: [SPI@1.0]
ResolveLibrary(SPI.h)
-> candidates: [SPI@1.0]
"C:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10816 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TFTLCD_Library" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TouchScreen" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\EEPROM\\src" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Fonts" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "C:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library\\Adafruit_SPITFT.cpp" -o nul
"C:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10816 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TFTLCD_Library" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TouchScreen" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\EEPROM\\src" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Fonts" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "C:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library\\glcdfont.c" -o nul
"C:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10816 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TFTLCD_Library" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TouchScreen" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\EEPROM\\src" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Fonts" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "C:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TFTLCD_Library\\Adafruit_TFTLCD.cpp" -o nul
"C:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10816 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TFTLCD_Library" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TouchScreen" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\EEPROM\\src" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Fonts" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "C:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TouchScreen\\TouchScreen.cpp" -o nul
"C:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10816 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TFTLCD_Library" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TouchScreen" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\EEPROM\\src" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Fonts" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "C:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src\\SPI.cpp" -o nul
Generating function prototypes...
"C:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10816 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TFTLCD_Library" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TouchScreen" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\EEPROM\\src" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Fonts" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "C:\\Users\\MIGUE_~1\\AppData\\Local\\Temp\\arduino_build_650694\\sketch\\sonda10k.ino.cpp" -o "C:\\Users\\MIGUE_~1\\AppData\\Local\\Temp\\arduino_build_650694\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\arduino-1.8.16\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\MIGUE_~1\\AppData\\Local\\Temp\\arduino_build_650694\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10816 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TFTLCD_Library" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TouchScreen" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\EEPROM\\src" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Fonts" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "C:\\Users\\MIGUE_~1\\AppData\\Local\\Temp\\arduino_build_650694\\sketch\\sonda10k.ino.cpp" -o "C:\\Users\\MIGUE_~1\\AppData\\Local\\Temp\\arduino_build_650694\\sketch\\sonda10k.ino.cpp.o"
Compiling libraries...
Compiling library "Adafruit_GFX_Library"
"C:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10816 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TFTLCD_Library" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TouchScreen" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\EEPROM\\src" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Fonts" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "C:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library\\glcdfont.c" -o "C:\\Users\\MIGUE_~1\\AppData\\Local\\Temp\\arduino_build_650694\\libraries\\Adafruit_GFX_Library\\glcdfont.c.o"
"C:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10816 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TFTLCD_Library" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TouchScreen" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\EEPROM\\src" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Fonts" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "C:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library\\Adafruit_SPITFT.cpp" -o "C:\\Users\\MIGUE_~1\\AppData\\Local\\Temp\\arduino_build_650694\\libraries\\Adafruit_GFX_Library\\Adafruit_SPITFT.cpp.o"
"C:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10816 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TFTLCD_Library" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TouchScreen" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\EEPROM\\src" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Fonts" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "C:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library\\Adafruit_GFX.cpp" -o "C:\\Users\\MIGUE_~1\\AppData\\Local\\Temp\\arduino_build_650694\\libraries\\Adafruit_GFX_Library\\Adafruit_GFX.cpp.o"
Compiling library "Adafruit_TFTLCD_Library"
Using previously compiled file: C:\Users\MIGUE_~1\AppData\Local\Temp\arduino_build_650694\libraries\Adafruit_TFTLCD_Library\Adafruit_TFTLCD.cpp.o
Compiling library "Adafruit_TouchScreen"
Using previously compiled file: C:\Users\MIGUE_~1\AppData\Local\Temp\arduino_build_650694\libraries\Adafruit_TouchScreen\TouchScreen.cpp.o
Compiling library "EEPROM"
Compiling library "Fonts"
Compiling library "SPI"
Using previously compiled file: C:\Users\MIGUE_~1\AppData\Local\Temp\arduino_build_650694\libraries\SPI\SPI.cpp.o
Compiling core...
Using precompiled core: C:\Users\MIGUE_~1\AppData\Local\Temp\arduino_cache_448091\core\core_arduino_avr_uno_e286c00a46c682fad353ddc8d3a24093.a
Linking everything together...
"C:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\\Users\\MIGUE_~1\\AppData\\Local\\Temp\\arduino_build_650694/sonda10k.ino.elf" "C:\\Users\\MIGUE_~1\\AppData\\Local\\Temp\\arduino_build_650694\\sketch\\sonda10k.ino.cpp.o" "C:\\Users\\MIGUE_~1\\AppData\\Local\\Temp\\arduino_build_650694\\libraries\\Adafruit_GFX_Library\\glcdfont.c.o" "C:\\Users\\MIGUE_~1\\AppData\\Local\\Temp\\arduino_build_650694\\libraries\\Adafruit_GFX_Library\\Adafruit_GFX.cpp.o" "C:\\Users\\MIGUE_~1\\AppData\\Local\\Temp\\arduino_build_650694\\libraries\\Adafruit_GFX_Library\\Adafruit_SPITFT.cpp.o" "C:\\Users\\MIGUE_~1\\AppData\\Local\\Temp\\arduino_build_650694\\libraries\\Adafruit_TFTLCD_Library\\Adafruit_TFTLCD.cpp.o" "C:\\Users\\MIGUE_~1\\AppData\\Local\\Temp\\arduino_build_650694\\libraries\\Adafruit_TouchScreen\\TouchScreen.cpp.o" "C:\\Users\\MIGUE_~1\\AppData\\Local\\Temp\\arduino_build_650694\\libraries\\SPI\\SPI.cpp.o" "C:\\Users\\MIGUE_~1\\AppData\\Local\\Temp\\arduino_build_650694/..\\arduino_cache_448091\\core\\core_arduino_avr_uno_e286c00a46c682fad353ddc8d3a24093.a" "-LC:\\Users\\MIGUE_~1\\AppData\\Local\\Temp\\arduino_build_650694" -lm
"C:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\MIGUE_~1\\AppData\\Local\\Temp\\arduino_build_650694/sonda10k.ino.elf" "C:\\Users\\MIGUE_~1\\AppData\\Local\\Temp\\arduino_build_650694/sonda10k.ino.eep"
"C:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -R .eeprom "C:\\Users\\MIGUE_~1\\AppData\\Local\\Temp\\arduino_build_650694/sonda10k.ino.elf" "C:\\Users\\MIGUE_~1\\AppData\\Local\\Temp\\arduino_build_650694/sonda10k.ino.hex"
Multiple libraries were found for "Adafruit_GFX.h"
Used: C:\Users\migue_000\Documents\Arduino\libraries\Adafruit_GFX_Library
Not used: C:\Users\migue_000\Documents\Arduino\libraries\Adafruit_GFX_Library-1.10.12
Not used: C:\Users\migue_000\Documents\Arduino\libraries\Adafruit_GFX_Library-1.9.0
Using library Adafruit_GFX_Library at version 1.5.3 in folder: C:\Users\migue_000\Documents\Arduino\libraries\Adafruit_GFX_Library
Using library Adafruit_TFTLCD_Library at version 1.0.3 in folder: C:\Users\migue_000\Documents\Arduino\libraries\Adafruit_TFTLCD_Library
Using library Adafruit_TouchScreen at version 1.1.2 in folder: C:\Users\migue_000\Documents\Arduino\libraries\Adafruit_TouchScreen
Using library EEPROM at version 2.0 in folder: C:\Users\migue_000\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\EEPROM
Using library Fonts in folder: C:\Users\migue_000\Documents\Arduino\libraries\Fonts (legacy)
Using library SPI at version 1.0 in folder: C:\Users\migue_000\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI
"C:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-size" -A "C:\\Users\\MIGUE_~1\\AppData\\Local\\Temp\\arduino_build_650694/sonda10k.ino.elf"
Sketch uses 29388 bytes (91%) of program storage space. Maximum is 32256 bytes.
Global variables use 629 bytes (30%) of dynamic memory, leaving 1419 bytes for local variables. Maximum is 2048 bytes.
And this is the compile report without any orange lines:
Alternatives for Adafruit_GFX.h: [Adafruit_GFX_Library@1.5.3 Adafruit_GFX_Library-1.9.0@1.9.0 Adafruit_GFX_Library-1.10.12@1.10.12]
-> candidates: [Adafruit_GFX_Library@1.5.3 Adafruit_GFX_Library-1.9.0@1.9.0 Adafruit_GFX_Library-1.10.12@1.10.12]
"C:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10816 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library-1.9.0" "C:\\Users\\MIGUE_~1\\AppData\\Local\\Temp\\arduino_build_650694\\sketch\\sonda10k.ino.cpp" -o nul
"C:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10816 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library-1.9.0" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TFTLCD_Library" "C:\\Users\\MIGUE_~1\\AppData\\Local\\Temp\\arduino_build_650694\\sketch\\sonda10k.ino.cpp" -o nul
"C:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10816 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library-1.9.0" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TFTLCD_Library" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TouchScreen" "C:\\Users\\MIGUE_~1\\AppData\\Local\\Temp\\arduino_build_650694\\sketch\\sonda10k.ino.cpp" -o nul
"C:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10816 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library-1.9.0" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TFTLCD_Library" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TouchScreen" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\EEPROM\\src" "C:\\Users\\MIGUE_~1\\AppData\\Local\\Temp\\arduino_build_650694\\sketch\\sonda10k.ino.cpp" -o nul
"C:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10816 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library-1.9.0" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TFTLCD_Library" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TouchScreen" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\EEPROM\\src" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Fonts" "C:\\Users\\MIGUE_~1\\AppData\\Local\\Temp\\arduino_build_650694\\sketch\\sonda10k.ino.cpp" -o nul
"C:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10816 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library-1.9.0" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TFTLCD_Library" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TouchScreen" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\EEPROM\\src" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Fonts" "C:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library-1.9.0\\Adafruit_GFX.cpp" -o nul
"C:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10816 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library-1.9.0" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TFTLCD_Library" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TouchScreen" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\EEPROM\\src" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Fonts" "C:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library-1.9.0\\Adafruit_MonoOLED.cpp" -o nul
Alternatives for Adafruit_I2CDevice.h: [Adafruit_BusIO@1.9.3]
ResolveLibrary(Adafruit_I2CDevice.h)
-> candidates: [Adafruit_BusIO@1.9.3]
"C:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10816 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library-1.9.0" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TFTLCD_Library" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TouchScreen" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\EEPROM\\src" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Fonts" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "C:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library-1.9.0\\Adafruit_MonoOLED.cpp" -o nul
Alternatives for Wire.h: [Wire@1.0]
ResolveLibrary(Wire.h)
-> candidates: [Wire@1.0]
"C:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10816 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library-1.9.0" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TFTLCD_Library" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TouchScreen" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\EEPROM\\src" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Fonts" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src" "C:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library-1.9.0\\Adafruit_MonoOLED.cpp" -o nul
"C:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10816 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library-1.9.0" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TFTLCD_Library" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TouchScreen" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\EEPROM\\src" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Fonts" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "C:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library-1.9.0\\Adafruit_MonoOLED.cpp" -o nul
"C:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10816 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library-1.9.0" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TFTLCD_Library" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TouchScreen" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\EEPROM\\src" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Fonts" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "C:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library-1.9.0\\Adafruit_SPITFT.cpp" -o nul
"C:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10816 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library-1.9.0" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TFTLCD_Library" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TouchScreen" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\EEPROM\\src" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Fonts" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "C:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library-1.9.0\\glcdfont.c" -o nul
"C:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10816 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library-1.9.0" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TFTLCD_Library" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TouchScreen" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\EEPROM\\src" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Fonts" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "C:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TFTLCD_Library\\Adafruit_TFTLCD.cpp" -o nul
"C:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10816 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library-1.9.0" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TFTLCD_Library" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TouchScreen" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\EEPROM\\src" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Fonts" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "C:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TouchScreen\\TouchScreen.cpp" -o nul
"C:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10816 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library-1.9.0" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TFTLCD_Library" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TouchScreen" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\EEPROM\\src" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Fonts" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "C:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_BusIO\\Adafruit_BusIO_Register.cpp" -o nul
"C:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10816 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library-1.9.0" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TFTLCD_Library" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TouchScreen" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\EEPROM\\src" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Fonts" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "C:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_BusIO\\Adafruit_I2CDevice.cpp" -o nul
"C:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10816 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library-1.9.0" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TFTLCD_Library" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TouchScreen" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\EEPROM\\src" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Fonts" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "C:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_BusIO\\Adafruit_SPIDevice.cpp" -o nul
"C:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10816 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library-1.9.0" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TFTLCD_Library" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TouchScreen" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\EEPROM\\src" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Fonts" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "C:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src\\Wire.cpp" -o nul
"C:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10816 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library-1.9.0" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TFTLCD_Library" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TouchScreen" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\EEPROM\\src" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Fonts" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "C:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src\\utility\\twi.c" -o nul
"C:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10816 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library-1.9.0" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TFTLCD_Library" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TouchScreen" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\EEPROM\\src" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Fonts" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "C:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src\\SPI.cpp" -o nul
"C:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10816 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library-1.9.0" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TFTLCD_Library" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TouchScreen" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\EEPROM\\src" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Fonts" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "C:\\Users\\MIGUE_~1\\AppData\\Local\\Temp\\arduino_build_650694\\sketch\\sonda10k.ino.cpp" -o "C:\\Users\\MIGUE_~1\\AppData\\Local\\Temp\\arduino_build_650694\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10816 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library-1.9.0" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TFTLCD_Library" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TouchScreen" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\EEPROM\\src" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Fonts" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "C:\\Users\\MIGUE_~1\\AppData\\Local\\Temp\\arduino_build_650694\\sketch\\sonda10k.ino.cpp" -o "C:\\Users\\MIGUE_~1\\AppData\\Local\\Temp\\arduino_build_650694\\sketch\\sonda10k.ino.cpp.o"
Compiling library "Adafruit_GFX_Library-1.9.0"
"C:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10816 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library-1.9.0" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TFTLCD_Library" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TouchScreen" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\EEPROM\\src" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Fonts" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "C:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library-1.9.0\\glcdfont.c" -o "C:\\Users\\MIGUE_~1\\AppData\\Local\\Temp\\arduino_build_650694\\libraries\\Adafruit_GFX_Library-1.9.0\\glcdfont.c.o"
"C:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10816 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library-1.9.0" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TFTLCD_Library" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TouchScreen" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\EEPROM\\src" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Fonts" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "C:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library-1.9.0\\Adafruit_GFX.cpp" -o "C:\\Users\\MIGUE_~1\\AppData\\Local\\Temp\\arduino_build_650694\\libraries\\Adafruit_GFX_Library-1.9.0\\Adafruit_GFX.cpp.o"
"C:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10816 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library-1.9.0" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TFTLCD_Library" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TouchScreen" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\EEPROM\\src" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Fonts" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "C:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library-1.9.0\\Adafruit_MonoOLED.cpp" -o "C:\\Users\\MIGUE_~1\\AppData\\Local\\Temp\\arduino_build_650694\\libraries\\Adafruit_GFX_Library-1.9.0\\Adafruit_MonoOLED.cpp.o"
"C:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10816 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library-1.9.0" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TFTLCD_Library" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TouchScreen" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\EEPROM\\src" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Fonts" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "C:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library-1.9.0\\Adafruit_SPITFT.cpp" -o "C:\\Users\\MIGUE_~1\\AppData\\Local\\Temp\\arduino_build_650694\\libraries\\Adafruit_GFX_Library-1.9.0\\Adafruit_SPITFT.cpp.o"
Compiling library "Adafruit_BusIO"
"C:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10816 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library-1.9.0" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TFTLCD_Library" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TouchScreen" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\EEPROM\\src" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Fonts" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "C:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_BusIO\\Adafruit_BusIO_Register.cpp" -o "C:\\Users\\MIGUE_~1\\AppData\\Local\\Temp\\arduino_build_650694\\libraries\\Adafruit_BusIO\\Adafruit_BusIO_Register.cpp.o"
"C:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10816 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library-1.9.0" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TFTLCD_Library" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TouchScreen" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\EEPROM\\src" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Fonts" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "C:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_BusIO\\Adafruit_I2CDevice.cpp" -o "C:\\Users\\MIGUE_~1\\AppData\\Local\\Temp\\arduino_build_650694\\libraries\\Adafruit_BusIO\\Adafruit_I2CDevice.cpp.o"
"C:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10816 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library-1.9.0" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TFTLCD_Library" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TouchScreen" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\EEPROM\\src" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Fonts" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "C:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_BusIO\\Adafruit_SPIDevice.cpp" -o "C:\\Users\\MIGUE_~1\\AppData\\Local\\Temp\\arduino_build_650694\\libraries\\Adafruit_BusIO\\Adafruit_SPIDevice.cpp.o"
Compiling library "Wire"
"C:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10816 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library-1.9.0" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TFTLCD_Library" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TouchScreen" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\EEPROM\\src" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Fonts" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "C:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src\\Wire.cpp" -o "C:\\Users\\MIGUE_~1\\AppData\\Local\\Temp\\arduino_build_650694\\libraries\\Wire\\Wire.cpp.o"
"C:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10816 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library-1.9.0" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TFTLCD_Library" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_TouchScreen" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\EEPROM\\src" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Fonts" "-IC:\\Users\\migue_000\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src" "-IC:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "C:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src\\utility\\twi.c" -o "C:\\Users\\MIGUE_~1\\AppData\\Local\\Temp\\arduino_build_650694\\libraries\\Wire\\utility\\twi.c.o"
Compiling core...
"C:\\Users\\migue_000\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\\Users\\MIGUE_~1\\AppData\\Local\\Temp\\arduino_build_650694/sonda10k.ino.elf" "C:\\Users\\MIGUE_~1\\AppData\\Local\\Temp\\arduino_build_650694\\sketch\\sonda10k.ino.cpp.o" "C:\\Users\\MIGUE_~1\\AppData\\Local\\Temp\\arduino_build_650694\\libraries\\Adafruit_GFX_Library-1.9.0\\glcdfont.c.o" "C:\\Users\\MIGUE_~1\\AppData\\Local\\Temp\\arduino_build_650694\\libraries\\Adafruit_GFX_Library-1.9.0\\Adafruit_GFX.cpp.o" "C:\\Users\\MIGUE_~1\\AppData\\Local\\Temp\\arduino_build_650694\\libraries\\Adafruit_GFX_Library-1.9.0\\Adafruit_MonoOLED.cpp.o" "C:\\Users\\MIGUE_~1\\AppData\\Local\\Temp\\arduino_build_650694\\libraries\\Adafruit_GFX_Library-1.9.0\\Adafruit_SPITFT.cpp.o" "C:\\Users\\MIGUE_~1\\AppData\\Local\\Temp\\arduino_build_650694\\libraries\\Adafruit_TFTLCD_Library\\Adafruit_TFTLCD.cpp.o" "C:\\Users\\MIGUE_~1\\AppData\\Local\\Temp\\arduino_build_650694\\libraries\\Adafruit_TouchScreen\\TouchScreen.cpp.o" "C:\\Users\\MIGUE_~1\\AppData\\Local\\Temp\\arduino_build_650694\\libraries\\Adafruit_BusIO\\Adafruit_BusIO_Register.cpp.o" "C:\\Users\\MIGUE_~1\\AppData\\Local\\Temp\\arduino_build_650694\\libraries\\Adafruit_BusIO\\Adafruit_I2CDevice.cpp.o" "C:\\Users\\MIGUE_~1\\AppData\\Local\\Temp\\arduino_build_650694\\libraries\\Adafruit_BusIO\\Adafruit_SPIDevice.cpp.o" "C:\\Users\\MIGUE_~1\\AppData\\Local\\Temp\\arduino_build_650694\\libraries\\Wire\\Wire.cpp.o" "C:\\Users\\MIGUE_~1\\AppData\\Local\\Temp\\arduino_build_650694\\libraries\\Wire\\utility\\twi.c.o" "C:\\Users\\MIGUE_~1\\AppData\\Local\\Temp\\arduino_build_650694\\libraries\\SPI\\SPI.cpp.o" "C:\\Users\\MIGUE_~1\\AppData\\Local\\Temp\\arduino_build_650694/..\\arduino_cache_448091\\core\\core_arduino_avr_uno_e286c00a46c682fad353ddc8d3a24093.a" "-LC:\\Users\\MIGUE_~1\\AppData\\Local\\Temp\\arduino_build_650694" -lm
Used: C:\Users\migue_000\Documents\Arduino\libraries\Adafruit_GFX_Library-1.9.0
Using library Adafruit_GFX_Library-1.9.0 at version 1.9.0 in folder: C:\Users\migue_000\Documents\Arduino\libraries\Adafruit_GFX_Library-1.9.0
Using library Adafruit_BusIO at version 1.9.3 in folder: C:\Users\migue_000\Documents\Arduino\libraries\Adafruit_BusIO
Using library Wire at version 1.0 in folder: C:\Users\migue_000\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire
Sketch uses 30458 bytes (94%) of program storage space. Maximum is 32256 bytes.
Global variables use 743 bytes (36%) of dynamic memory, leaving 1305 bytes for local variables. Maximum is 2048 bytes.
