Very confused
Hi everyone,
I just got started on this whole arduino thing,and can not for the life of me figure out the code for circuit 6 on this PDF, can anyone please help me!!??
Welcome to the Forum. Please read the second and third posts at the top of the Forum page, then get the code your are talking about and post it here using the code tags as explained in the two posts. You will get a lot more response if you post the code in question.
I don't actually have anything to base this off of, and I have no idea how to start :-[
Start simple.
Do you know how to read the value on an analogue pin ?
HINT - there is an example in the IDE
Ok, so the code for that part of the SIK is here:
SparkFun Inventor's Kit
Example sketch 06
PHOTO RESISTOR
  Use a photoresistor (light sensor) to control the brightness
  of a LED.
Hardware connections:
  Photo resistor:
    Connect one side of the photoresistor to 5 Volts (5V).
    Connect the other side of the photoresistor to ANALOG pin 0.
    Connect a 10K resistor between ANALOG pin 0 and GND.
    This creates a voltage divider, with the photoresistor one
    of the two resistors. The output of the voltage divider
    (connected to A0) will vary with the light level.
  LED:
    Connect the positive side (long leg) of the LED to
    digital pin 9. (To vary the brightness, this pin must
    support PWM, which is indicated by "~" or "PWM" on the
    Arduino itself.)
    Connect the negative side of the LED (short leg) to a
    330 Ohm resistor.
    Connect the other side of the resistor to GND.
This sketch was written by SparkFun Electronics,
with lots of help from the Arduino community.
This code is completely free for any use.
Visit http://learn.sparkfun.com/products/2 for SIK information.
Visit http://www.arduino.cc to learn about the Arduino.
Version 2.0 6/2012 MDG
// As usual, we'll create constants to name the pins we're using.
// This will make it easier to follow the code below.
const int sensorPin = 0;
const int ledPin = 9;
// We'll also set up some global variables for the light level:
int lightLevel, high = 0, low = 1023;
  // We'll set up the LED pin to be an output.
  // (We don't need to do anything special to use the analog input.)
  pinMode(ledPin, OUTPUT);
  // Just as we've done in the past, we'll use the analogRead()
  // function to measure the voltage coming from the photoresistor
  // resistor pair. This number can range between 0 (0 Volts) and
  // 1023 (5 Volts), but this circuit will have a smaller range
  // between dark and light.
  lightLevel = analogRead(sensorPin);
  // We now want to use this number to control the brightness of
  // the LED. But we have a problem: the analogRead() function
  // returns values between 0 and 1023, and the analogWrite()
  // function wants values from 0 to 255.
  // We can solve this by using two handy functions called map()
  // and constrain(). Map will change one range of values into
  // another range. If we tell map() our "from" range is 0-1023,
  // and our "to" range is 0-255, map() will squeeze the larger
  // range into the smaller. (It can do this for any two ranges.)
  // lightLevel = map(lightLevel, 0, 1023, 0, 255);
  // Because map() could still return numbers outside the "to"
  // range, (if they're outside the "from" range), we'll also use
  // a function called constrain() that will "clip" numbers into
  // a given range. If the number is above the range, it will reset
  // it to be the highest number in the range. If the number is
  // below the range, it will reset it to the lowest number.
  // If the number is within the range, it will stay the same.
  // lightLevel = constrain(lightLevel, 0, 255);
  // Here's one last thing to think about. The circuit we made
  // won't have a range all the way from 0 to 5 Volts. It will
  // be a smaller range, such as 300 (dark) to 800 (light).
  // If we just pass this number directly to map(), the LED will
  // change brightness, but it will never be completely off or
  // completely on.
  // You can fix this two ways, each of which we'll show
  // in the functions below. Uncomment ONE of them to
  // try it out:
  manualTune();  // manually change the range from light to dark
  //autoTune();  // have the Arduino do the work for us!
  // The above functions will alter lightLevel to be cover the
  // range from full-on to full-off. Now we can adjust the
  // brightness of the LED:
  analogWrite(ledPin, lightLevel);
  // The above statement will brighten the LED along with the
  // light level. To do the opposite, replace "lightLevel" in the
  // above analogWrite() statement with "255-lightLevel".
  // Now you've created a night-light!
void manualTune()
  // As we mentioned above, the light-sensing circuit we built
  // won't have a range all the way from 0 to 1023. It will likely
  // be more like 300 (dark) to 800 (light). If you run this sketch
  // as-is, the LED won't fully turn off, even in the dark.
  // You can accommodate the reduced range by manually
  // tweaking the "from" range numbers in the map() function.
  // Here we're using the full range of 0 to 1023.
  // Try manually changing this to a smaller range (300 to 800
  // is a good guess), and try it out again. If the LED doesn't
  // go completely out, make the low number larger. If the LED
  // is always too bright, make the high number smaller.
  // Remember you're JUST changing the 0, 1023 in the line below!
  // Now we'll return to the main loop(), and send lightLevel
  // to the LED.
void autoTune()
  // In the manualTune() function above, you need to repeatedly
  // change the values and try the program again until it works.
  // But why should you have to do that work? You've got a
  // computer in your hands that can figure things out for itself!
  // In this function, the Arduino will keep track of the highest
  // and lowest values that we're reading from analogRead().
  // If you look at the top of the sketch, you'll see that we've
  // initialized "low" to be 1023. We'll save anything we read
  // that's lower than that:
  if (lightLevel < low)
    low = lightLevel;
  // We also initialized "high" to be 0. We'll save anything
  // we read that's higher than that:
  if (lightLevel > high)
    high = lightLevel;
  // Once we have the highest and lowest values, we can stick them
  // directly into the map() function. No manual tweaking needed!
  // One trick we'll do is to add a small offset to low and high,
  // to ensure that the LED is fully-off and fully-on at the limits
  // (otherwise it might flicker a little bit).
  lightLevel = map(lightLevel, low+30, high-30, 0, 255);
  // to the LED.
Now what part do you need help understanding?
