Hi, and thank you for your great help!
The project is an interactive design project. The idea is that when shouting in a room you get the room emplifying your anger
The Shouting is sensed by the Sound Sensor (this is the Sound sensor input. It is a sensor similar to this one: Sound sensitive lights w/ sound sensor & Arduino – PrinceTronics) then leds turn up and there is a big noise turns on.
The noise could be done be AdaFruit wave shield (By the Adafruit Wave Shield for Arduino Kit [v1.1] : ID 94 : $22.00 : Adafruit Industries, Unique & fun DIY electronics and kits)
Or be the Musical Instrument Shield (SparkFun Music Instrument Shield - DEV-10587 - SparkFun Electronics)
I checked each shield and sensor by itself. My question is how can I conncet them to the arduino all togeather.
- I checked the Sound Sensor with this code:
int DO = 2; //Pin for Digital Output - DO
int DA = A0; // Pin for Analog Output - AO
int sensorvalue = 0;
sensorvalue = analogRead(DA); //Read the analog value
Serial.print("Analog: ");
Serial.print(sensorvalue); //Print the analog value
Serial.print(" ");
Serial.print("Digital: ");
Serial.println(digitalRead(DO)); //Print the digital value
- And I checked the Musical Instrument Shield according to this code:
Spark Fun Electronics 2011
#include <SoftwareSerial.h>
SoftwareSerial mySerial(2, 3); // RX, TX
byte note = 0; //The MIDI note value to be played
byte resetMIDI = 4; //Tied to VS1053 Reset line
byte ledPin = 13; //MIDI traffic inidicator
int instrument = 0;
Serial.begin(57600);
//Setup soft serial for MIDI control
mySerial.begin(31250);
//Reset the VS1053
pinMode(resetMIDI, OUTPUT);
digitalWrite(resetMIDI, LOW);
delay(100);
digitalWrite(resetMIDI, HIGH);
delay(100);
talkMIDI(0xB0, 0x07, 120); //0xB0 is channel message, set channel volume to near max (127)
//Demo Basic MIDI instruments, GM1
Serial.println("Basic Instruments");
talkMIDI(0xB0, 0, 0x00); //Default bank GM1
//Change to different instrument
for(instrument = 0 ; instrument < 127 ; instrument++) {
Serial.print(" Instrument: ");
Serial.println(instrument, DEC);
talkMIDI(0xC0, instrument, 0); //Set instrument number. 0xC0 is a 1 data byte command
//Play notes from F#-0 (30) to F#-5 (90):
for (note = 30 ; note < 40 ; note++) {
Serial.print("N:");
Serial.println(note, DEC);
//Note on channel 1 (0x90), some note value (note), middle velocity (0x45):
noteOn(0, note, 60);
delay(50);
//Turn off the note with a given off/release velocity
noteOff(0, note, 60);
delay(50);
delay(100); //Delay between instruments
//Demo GM2 / Fancy sounds
Serial.println("Demo Fancy Sounds");
talkMIDI(0xB0, 0, 0x78); //Bank select drums
//For this bank 0x78, the instrument does not matter, only the note
for(instrument = 30 ; instrument < 31 ; instrument++) {
//Play fancy sounds from 'High Q' to 'Open Surdo [EXC 6]'
for (note = 27 ; note < 87 ; note++) {
Serial.print("N:");
delay(100);
delay(100);
//Demo Melodic
Serial.println("Demo Melodic? Sounds");
talkMIDI(0xB0, 0, 0x79); //Bank select Melodic
//These don't sound different from the main bank to me
for(instrument = 27 ; instrument < 87 ; instrument++) {
Serial.print("N:");
delay(50);
delay(50);
//Send a MIDI note-on message. Like pressing a piano key
//channel ranges from 0-15
void noteOn(byte channel, byte note, byte attack_velocity) {
talkMIDI( (0x90 | channel), note, attack_velocity);
//Send a MIDI note-off message. Like releasing a piano key
void noteOff(byte channel, byte note, byte release_velocity) {
talkMIDI( (0x80 | channel), note, release_velocity);
//Plays a MIDI note. Doesn't check to see that cmd is greater than 127, or that data values are less than 127
void talkMIDI(byte cmd, byte data1, byte data2) {
digitalWrite(ledPin, HIGH);
mySerial.write(cmd);
mySerial.write(data1);
//Some commands only have one data byte. All cmds less than 0xBn have 2 data bytes
//(sort of: MIDI Communication Protocol)
if( (cmd & 0xF0) <= 0xB0)
mySerial.write(data2);
digitalWrite(ledPin, LOW);
Thank You!
Lola
