Very Fast Triangular Wave
I’m currently trying to create a triangular waveform that will go as fast as possible with an Arduino Due, and have it act as an input to another device. I currently have it generating a triangular wave from 0 to 5V in 1/255 increments with 1 microsecond per increment. However, I need it to go much faster than this. I understand that Arduino products have a clock cycle time of 62.5ns, and I would like to tap into this if possible, however there is no delay function smaller than microseconds. I am rather new at programming Arduino products, so any help would be greatly appreciated. I understand that this may mean that I need to hack into the Arduino, and the programming language completely changes when you do that. If that is the case then could someone please give me a link with instructions on how to work with this new programming language? My current program with the delay in microseconds is attached. I thank you all ahead of time for your assistance.
Due_waveform.ino (379 Bytes)
The Due doesn't. Please, just post your code, in code tags.
Some keywords that may help.
Port Manipulation Timer (hardware timers) such as Timer0,Timer1 etc.
Take a look at the 555 datasheet, page 11. A cap is charged/discharged to make a pretty decent looking triangular waveform. Would that shape be good enough? http://www.ti.com/lit/ds/symlink/ne555.pdf Perhaps you could achieve similar with some filtering of a '328P Arduino output. You achieve 2 MHz with simple code, or up to 16 MHz with a fuse change to output the system clock on an output pin. 16M,8M,4M,2M,1M, 512K, 256k, 128K with clock divider setting.
demonwolf6669: I'm currently trying to create a triangular waveform that will go as fast as possible with an Arduino Due, and have it act as an input to another device. I currently have it generating a triangular wave from 0 to 5V in 1/255 increments with 1 microsecond per increment.
How are you getting 5V from a Due?
If it is a fixed frequency, i.e., one frequency as fast as possible, you can output the quickest square wave you can and then use a switched constant current source and a capacitor.
The 555 is just an RC exponential, not a triangle since it does not use a constant current source. 555 Timer
Or get one of these and control if from the Arduino: AD function generator
It costs about $10
You haven't specified what upper limit of frequency you are trying to achieve. Until you do, all you're going to get is guesswork.
Pete
