Very Large 7Seg display - Flourescent tubes
This is actually something made by a pair of artists, where my contribution was the Arduino code and a relay-switch-module to drive the 220V flourescent tubes. The original post is here http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1273837957
Originally estimated at a few tens of Euros/Dollars, and a brief moment to write the code and a few hours for the electronics it ended up costing about three times as much and more like 100 hours of work. There were unexpected ... problems.
Firstly the very simple&cheap interface circuit of one optoisolated triac driven directly by the Arduino and going directy to the tubes had to be changed for a Arduino to BCD-7Seg chip to transistors to relays. One circuit board became 5, and then the design was unstable and was replaced by a makeshift workaround using two Arduinos (one master, one slave) controlling two 7seg digits each (pincount limit). Why? Don't ask, it's too much typing for me :-/
The end product looks like this:
Still, it works, and only needs to last a month or two (depending on how often the exhibit is shown). The code was enhanced from a simple i++; delay(13minutes); to something that did its own integer->7Seg conversion, the same code runs in both master&slave and determines where it runs, and communication uses one single TX/RX line. Two push switches enable setting the counter to an arbitrary value.
Here is the display with a person in front, for showing the size (the display is very bright, but the iPhone camera adjusted this down a lot)
The exhibition venue has a link http://www.etikettmalmo.se/, but it ends soon (late November 2010)
When the exhibition is finished, I'll fix the problem so one Arduino can drive all 5 boards (each board latching it's digit's value).
Cool project, would like to have helped, but too far away from me :confused:
Why didn't you just use a mega instead? It should have plenty of digital pins to control all the relays :slight_smile:
Yes, indeed, but the available Arduinos were two Extreeme models.
Some shift registers(like the 595) would solve that and work easilly with the shiftOut() arduino function, so, is it a clock?
whatever it is, I like it :slight_smile:
there are lots of abandoned factories in maastricht... would be fun building something like that in one of them...
Inquisitive minds want to know ... :wink:
I used a latched BCD-7Seg chip on each board so one Extreeme could drive more than the required 5 digits, but the chip/board failed to work reliably without a major rework (effectivly start from scratch) even though on paper it was a good and correct solution. I've thought of shift regs or ather latch logic, too, but choose the BCD-7seg to keep it "simple and obvious" in design. It's not really a clock, even though it counts regulary
Ain't that always the way :slight_smile:
Well done though, and good on you for perservering to help these guys out.
Rob
Nice work.
Some years back I was involved in a flashing wall using florescent tubes. (they had 11 columns and 3 rows...but thats another story)
We tried all sorts of methods to get a resonable rate of flash.
In the end we used Phillips?? Dimmable ballasts, and simply shorted out the 10v DC control, which made the lamp drop to about 3%.
Worked really well, and saves on switching mains.
Cheers
Mark
There are fast start ballasts that provide 1500v to the lamp to create a fast arc, and thus enabling a faster rate of on-off.
What shall I say... giant project !! :wink:
