Let's say in a section of your code, you have delay (10000). While in the middle of the delay, and interrupt pin meets its requirements (CHANGE, LOW, etc.). Does the Arduino stop the delay timer, run the interrupt, and then come back? Or does it avoid the interrupt until the delay is ran?
Don't let's say that. Rather, let's suppose that you manage the pause without using the delay() function, then the question of what happens if/when an interrupt occurs does not arise
gcjr:
the interrupt is processed immediately without stopping the delay timer.
if the delay ends while the ISR is active, the code following the delay will be delayed until the ISR complete
No, the interrupt that updates the millis() timer is deferred during the ISR. Thus, neither millis() nor the delay count advances. So, when the ISR exits, the delay() will continue where it left off with no "credit" for the time spend in the ISR.
