Very slow LED pixel display with SK6812RGBW, Arduino Uno & Neopixel library
Howdy,
Have some basic code that I put together to control SK6812RGBW LEDs using Adafruit Neopixel Library.
The code works well for about 30 LEDs but any more than that and the LED pixel changes update very slowly when turning the potentiometers. Also the colors adjust and vary slightly (possibly due to lack of analog read value smoothing code?).
Is there a better way to structure this sketch so that the colors change quickly and without variance? My programming chops are rudimentary so please bear with me. Thank you.
  Control SK6812RGBW LEDs with Hue, Saturation and Brightness (HSB / HSV ) plus separate "whiteness" dimmer.
  Hue is change by right potentiometer
  Brightness stays constant at 255.
  Saturation stays constant at 255
  White diode controlled by left potentiometer.
  getRGB() function based on <http://www.codeproject.com/miscctrl/CPicker.asp>
  dim_curve idea by Jims
  based on code by kasperkamperman.com
#ifdef __AVR__
  #include <avr/power.h>
#endif
// Define which pin on the Audiolux is connected to the LED Data Input
#define PIN            6
// How many LEDs are attached to the Audiolux?
#define NUMPIXELS      300
// When we setup the NeoPixel library, we tell it how many pixels, and which pin to use to send signals.
// Note that for older NeoPixel strips you might need to change the third parameter--see the strandtest
// example for more information on possible values.
Adafruit_NeoPixel pixels = Adafruit_NeoPixel(NUMPIXELS, PIN, NEO_RWGB + NEO_KHZ800);
  dim_curve 'lookup table' to compensate for the nonlinearity of human vision.
  Used in the getRGB function on saturation and brightness to make 'dimming' look more natural.
  Exponential function used to create values below :
  x from 0 - 255 : y = round(pow( 2.0, x+64/40.0) - 1)
const byte dim_curve[] = {
    0,   1,   1,   2,   2,   2,   2,   2,   2,   3,   3,   3,   3,   3,   3,   3,
    3,   3,   3,   3,   3,   3,   3,   4,   4,   4,   4,   4,   4,   4,   4,   4,
    4,   4,   4,   5,   5,   5,   5,   5,   5,   5,   5,   5,   5,   6,   6,   6,
    6,   6,   6,   6,   6,   7,   7,   7,   7,   7,   7,   7,   8,   8,   8,   8,
    8,   8,   9,   9,   9,   9,   9,   9,   10,  10,  10,  10,  10,  11,  11,  11,
    11,  11,  12,  12,  12,  12,  12,  13,  13,  13,  13,  14,  14,  14,  14,  15,
    15,  15,  16,  16,  16,  16,  17,  17,  17,  18,  18,  18,  19,  19,  19,  20,
    20,  20,  21,  21,  22,  22,  22,  23,  23,  24,  24,  25,  25,  25,  26,  26,
    27,  27,  28,  28,  29,  29,  30,  30,  31,  32,  32,  33,  33,  34,  35,  35,
    36,  36,  37,  38,  38,  39,  40,  40,  41,  42,  43,  43,  44,  45,  46,  47,
    48,  48,  49,  50,  51,  52,  53,  54,  55,  56,  57,  58,  59,  60,  61,  62,
    63,  64,  65,  66,  68,  69,  70,  71,  73,  74,  75,  76,  78,  79,  81,  82,
    83,  85,  86,  88,  90,  91,  93,  94,  96,  98,  99,  101, 103, 105, 107, 109,
    110, 112, 114, 116, 118, 121, 123, 125, 127, 129, 132, 134, 136, 139, 141, 144,
    146, 149, 151, 154, 157, 159, 162, 165, 168, 171, 174, 177, 180, 183, 186, 190,
    193, 196, 200, 203, 207, 211, 214, 218, 222, 226, 230, 234, 238, 242, 248, 255,
int rgb_colors[3];
int hue;
int saturation;
int brightness;
int white;
  pixels.begin(); // This initializes the NeoPixel library.
  // Assign potentiometer knobs to variables
  int potControlWhiteness = analogRead(2); // assign analog reading of left potentiometer knob to control Whiteness
  int potControlHue = analogRead(3);  // assign analog reading of right potentiometer knob to control hue
  // set HSB & White values
  int hue = map(potControlHue, 0, 1023, 0, 255); // map right pot knob to 0-255 values of hue
  int saturation = 255;                               // saturation is a number between 0 - 255
  int brightness = 128;
  int whiteness = map(potControlWhiteness, 1023, 0, 0, 255); // map left pot knob to 0-255 values of Whiteness
  getRGB(hue,saturation,brightness,rgb_colors);   // converts HSB to RGB
  // For a set of NeoPixels the first NeoPixel is 0, second is 1, all the way up to the count of pixels minus one.
  for(int i=0;i<NUMPIXELS;i++){
    // pixels.Color takes RWGB values, from 0,0,0,0 up to 255,255,255,255
    pixels.setPixelColor(i, pixels.Color(rgb_colors[0],whiteness,rgb_colors[1],rgb_colors[2])); // Color order: R,W,G,B.
    pixels.show(); // This sends the updated pixel color to the hardware.
void getRGB(int hue, int sat, int val, int colors[3]) {
  /* convert hue, saturation and brightness ( HSB/HSV ) to RGB
     The dim_curve is used only on brightness/value and on saturation (inverted).
     This looks the most natural.
  val = dim_curve[val];
  sat = 255-dim_curve[255-sat];
  int r;
  int g;
  int b;
  int base;
  if (sat == 0) { // Acromatic color (gray). Hue doesn't mind.
    colors[0]=val;
    colors[1]=val;
    colors[2]=val;
  } else  {
    base = ((255 - sat) * val)>>8;
    switch(hue/60) {
    case 0:
        r = val;
        g = (((val-base)*hue)/60)+base;
        b = base;
    case 1:
        r = (((val-base)*(60-(hue%60)))/60)+base;
        g = val;
        b = base;
    case 2:
        r = base;
        g = val;
        b = (((val-base)*(hue%60))/60)+base;
    case 3:
        r = base;
        g = (((val-base)*(60-(hue%60)))/60)+base;
        b = val;
    case 4:
        r = (((val-base)*(hue%60))/60)+base;
        g = base;
        b = val;
    case 5:
        r = val;
        g = base;
        b = (((val-base)*(60-(hue%60)))/60)+base;
    colors[0]=r;
    colors[1]=g;
    colors[2]=b;
Typical beginner's mistake. Move the pixels.show call outside the loop setting the pixel's colour. As you have it you send out all the data to all the LEDs when changing every single LED.
Do it like this:-
    pixels.show(); // This sends the updated pixel color to the hardware. do it only after all the changes have been made.
Wow,
Glad that it was such a simple fix! Works nice and fast now.
Any advice on the other question? How to smoothen the readings from the potentiometer so that the colors do not flicker constantly?
What value of pots do you have. If over 10K read each pot twice in a row and just use the second value.
Otherwise make sure the grounds from the pots go directly to a different ground connector as your LED strip. If that still does not cure it then take and average. Say sum 10 readings and divide by 10 for each pot in turn.
