Very stupid code question regarding millis()
When run, will it not return:
True
True
True
True
What is "it", and where do you expect "it" to return to?
By reference I mean something the Arduino can compare something else to. If not a reference, what is it for?
From what I can see, the Arduino runs the gesture through the if and returns a value of either true or false. What I'm trying to figure out is what would be considered "true" coming out of the loop.
EDIT - Wait, it looks like it actually sends out multiple values. I'm less confused, but I still don't know what it does.
It's a comparison function! If gesture equals inputMatchup then it returns true, and if it doesn't, then it returns false. And then if it returns true, it executes that first if().
EDIT - Right?
A reference has a very specific meaning in C++; a reference is a little like a pointer, but is considered safer than a pointer
I know what a reference is in code. I just forgot they existed when I wrote that.
No, it returns either false (as soon as it finds a mismatch) or true.
I was thinking aloud.
Maybe think to yourself for a little longer before committing to keyboard.
Would it help if I put in some redundant curly-brackets?
boolean matches(int a[4], int b[4])
  for (int i = 0; i < 4; i++)
    if (a[i] != b[i])
      return false;
  return true;
And turned the 'for' loop into a 'while' loop?
  int i = 0;
  while ( i < 4)
    if (a[i] != b[i])
      return false;
    i++;
  return true;
And use just basic integer operations?
int matches(int a[4], int b[4])
  int i = 0;
  while ( i < 4)
    if (a[i] != b[i])
      return 0;
    i = i + 1;
  return 1;
@johnwasser maybe write it again using goto.
Or unroll the loop. :expressionless:
a7
  int sum = 0;
    sum += abs (a[i] - b[i]);
  return sum == 0;
I suggest
     unsigned long long longLongA = * (unsigned long long *) a;
     unsigned long long longLongB = * (unsigned long long *) b;
    return longLongA == longLongB;
a7
...it won't work on an ESP32, for example.
Good idea!
  if (a[0] != b[0])
    return 0;
  if (a[1] != b[1])
    return 0;
  if (a[2] != b[2])
    return 0;
  if (a[3] != b[3])
    return 0;
  return 1;
Your first revision makes the most sense to me.
Just remember that 'for', 'if/else', 'while', and 'do/while' statements can only contain one statement, but that statement can be a block statement (list of statements surrounded by '{' and '}').
Do they end up the same in the compiler? With and without the redundant brackets, I mean.
I would expect the generated code to be the same.
Okay. I used your code and modified it for all of the hand gestures I want to use in my wearable computer. Anything wrong?
int gesture[4];
int inputMatchupRightClick[4] = {HIGH, LOW, HIGH, HIGH};
int inputMatchupLeftClick[4] = {LOW, HIGH, HIGH, HIGH};
int inputMatchupSpace[4] = {HIGH, HIGH, LOW, HIGH};
int inputMatchupEnter[4] = {HIGH, LOW, LOW, HIGH};
int inputMatchupCaps[4] = {LOW, LOW, HIGH, HIGH};
    if (a[i] != b[i])
      return false;
  return true;
  pinMode(3, INPUT_PULLUP);
  pinMode(4, INPUT_PULLUP);
  pinMode(5, INPUT_PULLUP);
  pinMode(6, INPUT_PULLUP);
  static unsigned long lastUnmatchTime = 0;
  gesture[0] = digitalRead(3);
  gesture[1] = digitalRead(4);
  gesture[2] = digitalRead(5);
  gesture[3] = digitalRead(6);
  if (matches(gesture, inputMatchupRightClick))
    if (millis() - lastUnmatchTime >= 50)
     Serial.println("right click detected");
  else if (matches(gesture, inputMatchupLeftClick)
     Serial.println("left click detected");
  else if (matches(gesture, inputMatchupSpace)
    if (millis() - lastUnmatchTime >= 60)
     Serial.println("space detected");
  else if (matches(gesture, inputMatchupEnter)
     Serial.println("enter detected");
  else if (matches(gesture, inputMatchupCaps)
      Serial.println("caps detected");
  else{
    lastUnmatchTime = millis();
