Very Very new to Aduino looking for beginners corner!
Sorry for this
Ive looked and looked and according to the left hand pane others are asking similar,
While I'm an Automotive engineer and have a basic knowledge. I have never tried programming. I have used C++ for basic CFG analysis air flows etc
So Ive built an led strip for the Indicators for my car as a test, ( following this youtube video https://www.youtube.com/watch?v=gqaCwqRQ3gE&t=97s )
but as soon as I upload his sketch I run into all sorts of errors and of course don't know what they mean
Could someone point me in the right direction, either the correct place for this post or nudge in the right direction as to the error messages.
Kind regards
Stephen
PS I have dropped the sketch below and the error codes Just in case hope this is the right thing to do; thank you in advance
home/s/Arduino/CarInterface_copy_1/CarInterface_copy_1.ino:1:5: error: found ':' in nested-name-specifier, expected '::'
/home/s/Arduino/CarInterface_copy_1/CarInterface_copy_1.ino:1:1: error: 'Name' does not name a type
/home/s/Arduino/CarInterface_copy_1/CarInterface_copy_1.ino:65:25: error: variable or field 'indicatorAnimation' declared void
 void indicatorAnimation(CRGB *leds) {
/home/s/Arduino/CarInterface_copy_1/CarInterface_copy_1.ino:65:25: error: 'CRGB' was not declared in this scope
/home/s/Arduino/CarInterface_copy_1/CarInterface_copy_1.ino:65:25: note: suggested alternative: 'OCR0B'
                         OCR0B
/home/s/Arduino/CarInterface_copy_1/CarInterface_copy_1.ino:65:31: error: 'leds' was not declared in this scope
/home/s/Arduino/CarInterface_copy_1/CarInterface_copy_1.ino:65:31: note: suggested alternative: 'gets'
                               gets
/home/s/Arduino/CarInterface_copy_1/CarInterface_copy_1.ino: In function 'void setup()':
/home/s/Arduino/CarInterface_copy_1/CarInterface_copy_1.ino:32:2: error: 'FastLED' was not declared in this scope
  FastLED.addLeds<WS2812B, L_INDICATOR_LED_PIN, GRB>(L_Indicator_leds, 3).setCorrection(TypicalLEDStrip);
/home/s/Arduino/CarInterface_copy_1/CarInterface_copy_1.ino:32:18: error: 'WS2812B' was not declared in this scope
/home/s/Arduino/CarInterface_copy_1/CarInterface_copy_1.ino:32:27: error: 'L_INDICATOR_LED_PIN' was not declared in this scope
/home/s/Arduino/CarInterface_copy_1/CarInterface_copy_1.ino:32:48: error: 'GRB' was not declared in this scope
/home/s/Arduino/CarInterface_copy_1/CarInterface_copy_1.ino:32:48: note: suggested alternative: 'DDRB'
                                                DDRB
/home/s/Arduino/CarInterface_copy_1/CarInterface_copy_1.ino:32:53: error: 'L_Indicator_leds' was not declared in this scope
/home/s/Arduino/CarInterface_copy_1/CarInterface_copy_1.ino:32:88: error: 'TypicalLEDStrip' was not declared in this scope
/home/s/Arduino/CarInterface_copy_1/CarInterface_copy_1.ino:34:24: error: 'BRIGHTNESS' was not declared in this scope
  FastLED.setBrightness(BRIGHTNESS);
/home/s/Arduino/CarInterface_copy_1/CarInterface_copy_1.ino:36:11: error: 'L_INDICATOR_INPUT' was not declared in this scope
   pinMode(L_INDICATOR_INPUT, INPUT);
/home/s/Arduino/CarInterface_copy_1/CarInterface_copy_1.ino: In function 'void loop()':
/home/s/Arduino/CarInterface_copy_1/CarInterface_copy_1.ino:43:39: error: 'L_INDICATOR_INPUT' was not declared in this scope
   bool L_IndicatorInput = digitalRead(L_INDICATOR_INPUT);
/home/s/Arduino/CarInterface_copy_1/CarInterface_copy_1.ino:49:22: error: 'L_Indicator_leds' was not declared in this scope
   indicatorAnimation(L_Indicator_leds);
/home/s/Arduino/CarInterface_copy_1/CarInterface_copy_1.ino:49:22: note: suggested alternative: 'L_IndicatorInput'
                      L_IndicatorInput
/home/s/Arduino/CarInterface_copy_1/CarInterface_copy_1.ino:49:3: error: 'indicatorAnimation' was not declared in this scope
/home/s/Arduino/CarInterface_copy_1/CarInterface_copy_1.ino:49:3: note: suggested alternative: 'indicatorLEDsLit'
   indicatorLEDsLit
/home/s/Arduino/CarInterface_copy_1/CarInterface_copy_1.ino:53:22: error: 'L_Indicator_leds' was not declared in this scope
/home/s/Arduino/CarInterface_copy_1/CarInterface_copy_1.ino:53:22: note: suggested alternative: 'L_IndicatorInput'
                      L_IndicatorInput
/home/s/Arduino/CarInterface_copy_1/CarInterface_copy_1.ino:53:3: error: 'indicatorAnimation' was not declared in this scope
/home/s/Arduino/CarInterface_copy_1/CarInterface_copy_1.ino:53:3: note: suggested alternative: 'indicatorLEDsLit'
   indicatorLEDsLit
/home/s/Arduino/CarInterface_copy_1/CarInterface_copy_1.ino:58:14: error: 'L_Indicator_leds' has not been declared
   fill_solid(L_Indicator_leds:: 3, CRGB::Black);
/home/s/Arduino/CarInterface_copy_1/CarInterface_copy_1.ino:58:33: error: expected unqualified-id before numeric constant
/home/s/Arduino/CarInterface_copy_1/CarInterface_copy_1.ino:58:36: error: 'CRGB' has not been declared
/home/s/Arduino/CarInterface_copy_1/CarInterface_copy_1.ino:58:3: error: 'fill_solid' was not declared in this scope
/home/s/Arduino/CarInterface_copy_1/CarInterface_copy_1.ino:62:2: error: 'FastLED' was not declared in this scope
  FastLED.show();
/home/s/Arduino/CarInterface_copy_1/CarInterface_copy_1.ino: At global scope:
                         OCR0B
                               gets
exit status 1
Compilation error: found ':' in nested-name-specifier, expected '::'
from this sketch;
 Created:	3/17/2021 4:15:11 PM
 Author:	Mr Monkey
 Code and schematic demonstrating how to interface an Arduino with 12V signals
 from a vehicle. This code is for educational purposes only, and should not be
 used on public roads unless you know it is legal where you live.
include <FastLED.h>
define NUM_LEDS			    3
define INDICATOR_MS      30
define BRIGHTNESS        200
// Connections to the 12V signals from vehicle
define L_INDICATOR_INPUT	3
// Connections to the LED strips
define L_INDICATOR_LED_PIN	7
// LED arrays for the lights
define CRGB L_INDICATOR_LEDS[3];
// Used for indicator animation
uint8_t indicatorLEDsLit = 3;
	// Read the state of the inputs
	// Brake lights
	// Indicators
	if (L_IndicatorInput ) {
	else if (!L_IndicatorInput) {
	else {
	FastLED.show();
	for (int i = 0; i < indicatorLEDsLit; i++) {
		leds[i] = CRGB::Orange;
	EVERY_N_MILLISECONDS(INDICATOR_MS) {
		indicatorLEDsLit++;
		if (indicatorLEDsLit > 3) indicatorLEDsLit = 3;
miss # before include.
#include <FastLED.h>
and here
and here
  1. your code should begin with "/*", as many of those top lines are comments
  2. anywhere you have "include" or "define", it should actually be "#include" or "#define"
And these
L_Indicator_leds
are not the same as the #define. Capitalization matters.
Similar problems exist.
Bad copy/paste.
Try this:
 Author:	Scott Marley
#define NUM_LEDS			    9
#define INDICATOR_MS      30
#define BRIGHTNESS        200
#define BRAKE_INPUT			  4
#define L_INDICATOR_INPUT	3
#define R_INDICATOR_INPUT	2
#define L_BRAKE_LED_PIN		  8
#define R_BRAKE_LED_PIN		  9
#define L_INDICATOR_LED_PIN	7
#define R_INDICATOR_LED_PIN	6
CRGB l_brake_leds[NUM_LEDS];
CRGB r_brake_leds[NUM_LEDS];
CRGB l_indicator_leds[NUM_LEDS];
CRGB r_indicator_leds[NUM_LEDS];
uint8_t indicatorLEDsLit = 0;
	FastLED.addLeds<WS2812B, L_BRAKE_LED_PIN, GRB>(l_brake_leds, NUM_LEDS).setCorrection(TypicalLEDStrip);
	FastLED.addLeds<WS2812B, R_BRAKE_LED_PIN, GRB>(r_brake_leds, NUM_LEDS).setCorrection(TypicalLEDStrip);
	FastLED.addLeds<WS2812B, L_INDICATOR_LED_PIN, GRB>(l_indicator_leds, NUM_LEDS).setCorrection(TypicalLEDStrip);
	FastLED.addLeds<WS2812B, R_INDICATOR_LED_PIN, GRB>(r_indicator_leds, NUM_LEDS).setCorrection(TypicalLEDStrip);
	pinMode(BRAKE_INPUT, INPUT);
	pinMode(R_INDICATOR_INPUT, INPUT);
	bool brakeInput = digitalRead(BRAKE_INPUT);
	bool LIndicatorInput = digitalRead(L_INDICATOR_INPUT);
	bool RIndicatorInput = digitalRead(R_INDICATOR_INPUT);
	// Brake lights
	if (brakeInput) {
		fill_solid(l_brake_leds, NUM_LEDS, CRGB::Red);
		fill_solid(r_brake_leds, NUM_LEDS, CRGB::Red);
	else {
		fill_solid(l_brake_leds, NUM_LEDS, CRGB::Black);
		fill_solid(r_brake_leds, NUM_LEDS, CRGB::Black);
	// Indicators
	if (LIndicatorInput && !RIndicatorInput) {
		indicatorAnimation(l_indicator_leds);
	else if (RIndicatorInput && !LIndicatorInput) {
		indicatorAnimation(r_indicator_leds);
	// Hazards
	else if (LIndicatorInput && RIndicatorInput) {
		fill_solid(l_indicator_leds, NUM_LEDS, CRGB::Orange);
		fill_solid(r_indicator_leds, NUM_LEDS, CRGB::Orange);
	else {
		fill_solid(l_indicator_leds, NUM_LEDS, CRGB::Black);
		fill_solid(r_indicator_leds, NUM_LEDS, CRGB::Black);
	FastLED.show();
		indicatorLEDsLit++;
		if (indicatorLEDsLit > NUM_LEDS) indicatorLEDsLit = NUM_LEDS;
HTH
a7
Try your code modified simulated here:
Below, your code modified:
#define NUM_LEDS			    3
#define L_INDICATOR_INPUT	3           // Connections to the 12V signals from vehicle
#define L_INDICATOR_LED_PIN	7         // Connections to the LED strips
CRGB L_INDICATOR_LEDS[NUM_LEDS];      // LED arrays for the lights
uint8_t indicatorLEDsLit = 3;         // Used for indicator animation
  FastLED.addLeds<WS2812B, L_INDICATOR_LED_PIN, GRB>(L_INDICATOR_LEDS, NUM_LEDS).setCorrection(TypicalLEDStrip);
  // Brake lights
  // Indicators
    indicatorAnimation(L_INDICATOR_LEDS);
  else {
    fill_solid(L_INDICATOR_LEDS, NUM_LEDS, CRGB::Black);
  FastLED.show();
    indicatorLEDsLit++;
Multi-line comments using '/*' are terminated with a '*/' sequence.
@dougp look closely at the first post several lines in you'll find an unpaired
Funny, that whole top section of uncompilable verbiage becomes comment if you just do as I suggested and start with
Sheesh.
Thank you
Yes that was me deleting stuff to see if the error code changed
I had made a simple circuit with one LED and used the code in the tutorial , that worked but when I tried to upscale I got unstuck
Thank you for taking the time to reply
Stephen
Thank you
Thats a big help really good , I can try things out and learn
thank you
really appreciate that and you taking the time
Stephen
Sorry As I noted before , this was me deleting stuff and by this point I was lost and wandering around in circles
And when ur lost , go back to the beginning and try again !
Thank you for taking the time to reply !
Stephen
Ah, I see now.
