@Railroader, thanks for the reply
Here is the code.
What do you mean by Check JP2 to JP7? I was thinking I would have to get my solder out a literally short them? Thats how interpreted the data sheet png.
thanks
//VFD to Arduino
// 1 GND
// 2 VCC
// 3-SIO D11-MOSI
// 4-STB D10-Slave Select
// 5-SCK D13-SCK
#include <SPI.h>
const int slaveSelectPin = 10;
unsigned char UDF[13][8]=
0xff,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0xff,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0xff,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0xff,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0xff,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0xff,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0xff,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xff,
0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,
0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x08,
0x04,0x04,0x04,0x04,0x04,0x04,0x04,0x04,
0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x02,
0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,
unsigned char i,j,k;
unsigned char Seril_Demo_Line1[]={
' ',' ',' ',' ','V','F','D','-','D','I','S','P','L','A','Y',' ',' ',' ',' ',' ',
unsigned char Seril_Demo_Line2[]={
'M','O','D','E',':','S','E','R','I','A','L','-','D','E','M','O',' ',' ',' ',' ',
pinMode (slaveSelectPin, OUTPUT);
SPI.begin();
SPI.setDataMode(SPI_MODE3);
void cdelay(unsigned int t)
while(t--);
delay(100);
// delay(t);
void DATA(unsigned char temp_1)
digitalWrite(slaveSelectPin,LOW);
SPI.transfer(0xfa);
SPI.transfer(temp_1);
digitalWrite(slaveSelectPin,HIGH);
void COM(unsigned char temp_2)
SPI.transfer(0xf8);
SPI.transfer(temp_2);
COM(0x01); //clear all display and set DD-RAM address 0 in address counter
COM(0x02); //move cursor to the original position
COM(0x06); //set the cursor direction increment and cursor shift enabled
COM(0x38); //set 8bit operation,2 line display and 100% brightness level
COM(0x80); //set cursor to the first position of 1st line
COM(0x0c); //set display on,cursor on,blinking off
// COM(0x06); //set display on,cursor on,blinking on (this is a guess)
delay(10);
for (j=0; j<13; j++)
COM(0x40); //CGRAM ADDRESS SETTING
for (k=0; k<8; k++)
DATA(UDF[j][k]);
COM(0x80); //DRAM ADDRESS SETTING
for (i=0; i<80; i++)
DATA(0x00);
cdelay(20000);
cdelay(20);
COM(0x80);
for (i=0; i<20; i++)
DATA(Seril_Demo_Line1[i]);
COM(0xc0);
DATA(Seril_Demo_Line2[i]);
cdelay(50000);
cdelay(50000);
cdelay(50000);
cdelay(50000);
cdelay(50000);
cdelay(50000);
cdelay(50000);
cdelay(50000);
cdelay(50000);
cdelay(50000);
COM(0x80); //DDRAM ADDRESS SETTING
DATA(0x2a);
DATA(0x20);
DATA(0x20);
DATA(0x2a);
cdelay(50000);
cdelay(50000);
DATA(0x20);
DATA(0x2a);
DATA(0x2a);
DATA(0x20);
cdelay(50000);
cdelay(50000);
for (k=0; k<8; k++)
DATA(0xff);
DATA(0x00);
