VGAX library: display font problem
Hello,
i try to use an Anrduino Uno with the VGAX library from smaffer to show fonts on a vga monitor.
I used the following example code from the GitHub website:
#include <VGAX.h>
//font generated from 2BITFONT - by Sandro Maffiodo
#define FNT_UFONT_HEIGHT 6
#define FNT_UFONT_SYMBOLS_COUNT 95
//data size=570 bytes
const unsigned char fnt_ufont_data[FNT_UFONT_SYMBOLS_COUNT][1+FNT_UFONT_HEIGHT] PROGMEM={
{ 1, 128, 128, 128,   0, 128,   0, }, //glyph '!' code=0
{ 3, 160, 160,   0,   0,   0,   0, }, //glyph '"' code=1
{ 5,  80, 248,  80, 248,  80,   0, }, //glyph '#' code=2
{ 5, 120, 160, 112,  40, 240,   0, }, //glyph '
The problem is that my output doesn’t look really clean…
Here is a Picture.
What am i doing wrong? code=3 { 5, 136,  16,  32,  64, 136,   0, }, //glyph '%' code=4 { 5,  96, 144, 104, 144, 104,   0, }, //glyph '&' code=5 { 2, 128,  64,   0,   0,   0,   0, }, //glyph ''' code=6 { 2,  64, 128, 128, 128,  64,   0, }, //glyph '(' code=7 { 2, 128,  64,  64,  64, 128,   0, }, //glyph ')' code=8 { 3,   0, 160,  64, 160,   0,   0, }, //glyph '*' code=9 { 3,   0,  64, 224,  64,   0,   0, }, //glyph '+' code=10 { 2,   0,   0,   0,   0, 128,  64, }, //glyph ',' code=11 { 3,   0,   0, 224,   0,   0,   0, }, //glyph '-' code=12 { 1,   0,   0,   0,   0, 128,   0, }, //glyph '.' code=13 { 5,   8,  16,  32,  64, 128,   0, }, //glyph '/' code=14 { 4,  96, 144, 144, 144,  96,   0, }, //glyph '0' code=15 { 3,  64, 192,  64,  64, 224,   0, }, //glyph '1' code=16 { 4, 224,  16,  96, 128, 240,   0, }, //glyph '2' code=17 { 4, 224,  16,  96,  16, 224,   0, }, //glyph '3' code=18 { 4, 144, 144, 240,  16,  16,   0, }, //glyph '4' code=19 { 4, 240, 128, 224,  16, 224,   0, }, //glyph '5' code=20 { 4,  96, 128, 224, 144,  96,   0, }, //glyph '6' code=21 { 4, 240,  16,  32,  64,  64,   0, }, //glyph '7' code=22 { 4,  96, 144,  96, 144,  96,   0, }, //glyph '8' code=23 { 4,  96, 144, 112,  16,  96,   0, }, //glyph '9' code=24 { 1,   0, 128,   0, 128,   0,   0, }, //glyph ':' code=25 { 2,   0, 128,   0,   0, 128,  64, }, //glyph ';' code=26 { 3,  32,  64, 128,  64,  32,   0, }, //glyph '<' code=27 { 3,   0, 224,   0, 224,   0,   0, }, //glyph '=' code=28 { 3, 128,  64,  32,  64, 128,   0, }, //glyph '>' code=29 { 4, 224,  16,  96,   0,  64,   0, }, //glyph '?' code=30 { 4,  96, 144, 176, 128, 112,   0, }, //glyph '@' code=31 { 4,  96, 144, 240, 144, 144,   0, }, //glyph 'A' code=32 { 4, 224, 144, 224, 144, 224,   0, }, //glyph 'B' code=33 { 4, 112, 128, 128, 128, 112,   0, }, //glyph 'C' code=34 { 4, 224, 144, 144, 144, 224,   0, }, //glyph 'D' code=35 { 4, 240, 128, 224, 128, 240,   0, }, //glyph 'E' code=36 { 4, 240, 128, 224, 128, 128,   0, }, //glyph 'F' code=37 { 4, 112, 128, 176, 144, 112,   0, }, //glyph 'G' code=38 { 4, 144, 144, 240, 144, 144,   0, }, //glyph 'H' code=39 { 3, 224,  64,  64,  64, 224,   0, }, //glyph 'I' code=40 { 4, 240,  16,  16, 144,  96,   0, }, //glyph 'J' code=41 { 4, 144, 160, 192, 160, 144,   0, }, //glyph 'K' code=42 { 4, 128, 128, 128, 128, 240,   0, }, //glyph 'L' code=43 { 5, 136, 216, 168, 136, 136,   0, }, //glyph 'M' code=44 { 4, 144, 208, 176, 144, 144,   0, }, //glyph 'N' code=45 { 4,  96, 144, 144, 144,  96,   0, }, //glyph 'O' code=46 { 4, 224, 144, 224, 128, 128,   0, }, //glyph 'P' code=47 { 4,  96, 144, 144, 144,  96,  16, }, //glyph 'Q' code=48 { 4, 224, 144, 224, 160, 144,   0, }, //glyph 'R' code=49 { 4, 112, 128,  96,  16, 224,   0, }, //glyph 'S' code=50 { 3, 224,  64,  64,  64,  64,   0, }, //glyph 'T' code=51 { 4, 144, 144, 144, 144,  96,   0, }, //glyph 'U' code=52 { 3, 160, 160, 160, 160,  64,   0, }, //glyph 'V' code=53 { 5, 136, 168, 168, 168,  80,   0, }, //glyph 'W' code=54 { 4, 144, 144,  96, 144, 144,   0, }, //glyph 'X' code=55 { 3, 160, 160,  64,  64,  64,   0, }, //glyph 'Y' code=56 { 4, 240,  16,  96, 128, 240,   0, }, //glyph 'Z' code=57 { 2, 192, 128, 128, 128, 192,   0, }, //glyph '[' code=58 { 5, 128,  64,  32,  16,   8,   0, }, //glyph '\' code=59 { 2, 192,  64,  64,  64, 192,   0, }, //glyph ']' code=60 { 5,  32,  80, 136,   0,   0,   0, }, //glyph '^' code=61 { 4,   0,   0,   0,   0, 240,   0, }, //glyph '_' code=62 { 2, 128,  64,   0,   0,   0,   0, }, //glyph '’ code=63
{ 3,   0, 224,  32, 224, 224,   0, }, //glyph ‘a’ code=64
{ 3, 128, 224, 160, 160, 224,   0, }, //glyph ‘b’ code=65
{ 3,   0, 224, 128, 128, 224,   0, }, //glyph ‘c’ code=66
{ 3,  32, 224, 160, 160, 224,   0, }, //glyph ‘d’ code=67
{ 3,   0, 224, 224, 128, 224,   0, }, //glyph ‘e’ code=68
{ 2,  64, 128, 192, 128, 128,   0, }, //glyph ‘f’ code=69
{ 3,   0, 224, 160, 224,  32, 224, }, //glyph ‘g’ code=70
{ 3, 128, 224, 160, 160, 160,   0, }, //glyph ‘h’ code=71
{ 1, 128,   0,   128, 128, 128, 0, }, //glyph ‘i’ code=72
{ 2,   0, 192,  64,  64,  64, 128, }, //glyph ‘j’ code=73
{ 3, 128, 160, 192, 160, 160,   0, }, //glyph ‘k’ code=74
{ 1, 128, 128, 128, 128, 128,   0, }, //glyph ‘l’ code=75
{ 5,   0, 248, 168, 168, 168,   0, }, //glyph ‘m’ code=76
{ 3,   0, 224, 160, 160, 160,   0, }, //glyph ‘n’ code=77
{ 3,   0, 224, 160, 160, 224,   0, }, //glyph ‘o’ code=78
{ 3,   0, 224, 160, 160, 224, 128, }, //glyph ‘p’ code=79
{ 3,   0, 224, 160, 160, 224,  32, }, //glyph ‘q’ code=80
{ 3,   0, 224, 128, 128, 128,   0, }, //glyph ‘r’ code=81
{ 2,   0, 192, 128,  64, 192,   0, }, //glyph ‘s’ code=82
{ 3,  64, 224,  64,  64,  64,   0, }, //glyph ‘t’ code=83
{ 3,   0, 160, 160, 160, 224,   0, }, //glyph ‘u’ code=84
{ 3,   0, 160, 160, 160,  64,   0, }, //glyph ‘v’ code=85
{ 5,   0, 168, 168, 168,  80,   0, }, //glyph ‘w’ code=86
{ 3,   0, 160,  64, 160, 160,   0, }, //glyph ‘x’ code=87
{ 3,   0, 160, 160, 224,  32, 224, }, //glyph ‘y’ code=88
{ 2,   0, 192,  64, 128, 192,   0, }, //glyph ‘z’ code=89
{ 3,  96,  64, 192,  64,  96,   0, }, //glyph ‘{’ code=90
{ 1, 128, 128, 128, 128, 128,   0, }, //glyph ‘|’ code=91
{ 3, 192,  64,  96,  64, 192,   0, }, //glyph ‘}’ code=92
{ 3,  96, 192,   0,   0,   0,   0, }, //glyph ‘~’ code=93
{ 4,  48,  64, 224,  64, 240,   0, }, //glyph ‘£’ code=94
VGAX vga;
 static const char str0 PROGMEM=“VGAX Hello World!”;
 vga.begin();
 vga.clear(11);
 vga.printPROGMEM((byte*)fnt_ufont_data, FNT_UFONT_SYMBOLS_COUNT, FNT_UFONT_HEIGHT, 3, 1, str0, 10, 10, 1);
[/code]
Here is a Picture.
What am i doing wrong?`
Dear mario439, there is a chance that you are using a too old Arduino IDE. I had exactly the same problem and I solved it just updating the software. I am actually using Arduino IDE 1.6.4, but the latest one should work as well.
Mmm - could be. 1.0.6, 1.6.0~1.6.9, and 1.6.10~1.6.13 each use a different compiler version. That library may be picky about compiler version (it's the kind of thing that that's plausible with).
That's sort of suspicious how regular the glitch is, though...
Yes , if use Arduino IDE 1.6.10 all work good.Thx for all !
