sorry to post this here. I'm working on an arduino-controlled bristlebot design for a 3 hour class on physical computing but can't seem to source an appropriate pager or other vibrating motors. Does any one have a suggestion for possible suppliers?
An alternative solution: If you can find a regular motor the right size, just stick a weight on the shaft - if the weight isn't centered, it will vibrate.
It's really easy to do if you don't want it to happen :), so I'm guessing you could do it on purpose without too much trouble.
thanks - that's my backup plan (put a dab of hot glue or something on the motor shaft). However, I think we found a supplier for the vibrator motors at http://www.24.se/ShowProduct.aspx?prodID=1838. I think these will be small enough and easy to mount (important when doing a quick class!)
