Hi Everyone,
I'm new to coding and using Arduino and I was hoping someone might be able to help with a few issues I'm having with a project I'm working on.
I'm creating a vibration monitoring system to record the vibration created when a wheel crosses a gap in the surface it is rolling on. The wheel will be roll back and forth over this gap multiple times a day and each crossing must be recorded. In the final version of this I intend to incorporate a trigger system that will activate the recording, but for the time being having the recording controlled by a set delay is sufficient, as this is more of a proof case rather than the final product.
The hardware being used is an ESP32-DevkitC-V4, connected to a Model 4030 TE connectivity triaxial accelerometer, and a micro-Sd card module.
The accelerometer data is recorded and stored on the micro-SD card, and the csv produced is ideal for the post processing and visualization work I will be doing. I have written this code so that each crossing will be grouped with a group ID. This is done by having each reading assigned an ID and once this number reaches a certain value (depending on the sampling rate and recording time I want) the recording will stop and then a new group ID will be assigned for the next group of readings.
Current code:
// Libraries for SD card
#include "FS.h"
#include "SD.h"
#include "SPI.h"
// Define CS pin for the SD card module
#define SD_CS 5
// ID integers
int readingID = 1;
int groupID = 1;
String dataMessage;
// Sensor variables
float sensorPinX = 34; // select the input pin for the potentiometer
float sensorPinY = 32;
float sensorPinZ = 35;
float sensorValueX = 0; // variable to store the value coming from the sensor
float sensorValueY = 0;
float sensorValueZ = 0;
// Write to the SD card (DON'T MODIFY THIS FUNCTION)
void writeFile(fs::FS &fs, const char * path, const char * message) {
Serial.printf("Writing file: %s\n", path);
File file = fs.open(path, FILE_WRITE);
if(!file) {
Serial.println("Failed to open file for writing");
return;
if(file.print(message)) {
Serial.println("File written");
Serial.println("Write failed");
file.close();
// Append data to the SD card (DON'T MODIFY THIS FUNCTION)
void appendFile(fs::FS &fs, const char * path, const char * message) {
Serial.printf("Appending to file: %s\n", path);
File file = fs.open(path, FILE_APPEND);
if(!file) {
Serial.println("Failed to open file for appending");
return;
Serial.println("Message appended");
Serial.println("Append failed");
file.close();
// Start serial communication for debugging purposes
// Initialize SD card
SD.begin(SD_CS);
if(!SD.begin(SD_CS)) {
Serial.println("Card Mount Failed");
return;
uint8_t cardType = SD.cardType();
if(cardType == CARD_NONE) {
Serial.println("No SD card attached");
return;
Serial.println("Initializing SD card...");
if (!SD.begin(SD_CS)) {
Serial.println("ERROR - SD card initialization failed!");
return; // init failed
// If the .txt file doesn't exist
// Create a file on the SD card and write the data labels
File file = SD.open("/accelerometer.csv");
if(!file) {
Serial.println("File doens't exist");
Serial.println("Creating file...");
writeFile(SD, "/accelerometer.csv", "Group ID, Reading ID, X, Y, Z, SR = 100Hz, Sample Interval = 10s, Group Interval = 5min \r\n");
else {
Serial.println("File already exists");
file.close();
//for loop to group 1000 readings
//the groupID then increases by 1
//this would be a single pass
for (int groupID = 1; groupID <=300; groupID++){
//readings sampled at 100Hz for 10s
for (int readingID = 1; readingID <=1000; readingID++){
// read the value from the sensor:
sensorValueX = analogRead(sensorPinX)-2895;
sensorValueY = analogRead(sensorPinY)-2903;
sensorValueZ = analogRead(sensorPinZ)-4095;
//prints sensor readings with group and reading IDs:
Serial.print("G-ID = ");
Serial.print(groupID);
Serial.print("\t");
Serial.print("R-ID = ");
Serial.print(readingID);
Serial.print("\t");
Serial.print("X = ");
Serial.print(sensorValueX);
Serial.print("\t");
Serial.print("Y = ");
Serial.print(sensorValueY);
Serial.print("\t");
Serial.print("Z = ");
Serial.print(sensorValueZ);
//using the raw code from this function allows the correct int values to be used
//if pre-defined the wrong values are used:
dataMessage = String(groupID) + "," + String(readingID) + "," + String(sensorValueX) + "," + String(sensorValueY) + "," +
String(sensorValueZ) + "\r\n";
Serial.print("Save data: ");
Serial.println(dataMessage);
appendFile(SD, "/accelerometer.csv", dataMessage.c_str());
//sample rate
delay(10);
//time between groups
delay(60000);
delay(10000);
However, the issues I am facing are the naming of the .csv produced and the uploading of that .csv to a cloud server.
I want each cycle to create a new .csv file with the time and date as the file name – In this format YYMMDDHH:mm:ss.
I then want this file uploaded from the SD card to the cloud server to allow for remote access, as once installed I will not have access to the board or SD card.
Any advice would be greatly appreciated!
Thanks!
