I have a victor 883 speed controller that says it requires a pwm input. I powered up the victor 883 and sent it a pwm signal using the analogWrite() command. However the light on the victor 883 flashes orange which means that it isn't recieving the pwm signal.
Did a voltage check with a fluke meter and it appears that the voltage is coming accross the line. Tried to figure out what is going on. Some thoughts from me and my team member.
The victor act like a servo, and thought that it might need a servo type input. I say this because from the information that was provided by the a couple of website say that to control speed you send it a pwm between 0-125. 127 causes an idle. and anything above 127 is the opposite direction.
The website calls for a signal driver. Not quite sure what it is and not quite sure if we need it.
Any help would greatly be appreciated.
Thank you.
