I am attempting to use VE.Direct to monitor several solar controllers. Victron has some links to sample code. What I felt was the most complete code has turned out to be the most complex and not working code.
Below is the code that is suppose to connect to a Victron via VE.direct. If I use a very simple code "Serial2.Available()" i connect and start seeing messages on the serial monitor. If I use the below code It never connects. Can someone help me understand the serial.begin/flush/available/end area of this code and maybe offer some suggestions to why it doesnt ever read data.
VEDirect::VEDirect(HardwareSerial& port):
VESerial(port)
// Initialise the serial port that the
// VE.Direct device is connected to and
// store it for later use.
VEDirect::~VEDirect() {
// virtual destructor
uint8_t VEDirect::begin() {
// Check connection the serial port
VESerial.begin(19200);
if (VESerial) {
if(VESerial.available()) {
VESerial.flush();
VESerial.end();
return 1;
return 0;
int32_t VEDirect::read(uint8_t target) {
// Read VE.Direct lines from the serial port
// Search for the label specified by enum target
// Extract and return the corresponding value
// If value is "ON" return 1. If "OFF" return 0;
uint16_t loops = VED_MAX_READ_LOOPS;
uint8_t lines = VED_MAX_READ_LINES;
int32_t ret = 0; // The value to be returned
char line[VED_LINE_SIZE] = "\0"; // Line buffer
uint8_t idx = 0; // Line buffer index
char* label;
char* value_str;
int8_t b; // byte read from the stream
VESerial.begin(VED_BAUD_RATE);
while (lines > 0) {
if (VESerial.available()) {
while (loops > 0) {
b = VESerial.read();
if ((b == -1) || (b == '\r')) { // Ignore '\r' and empty reads
loops--;
if (b == '\n') { // EOL
if (idx < VED_LINE_SIZE) {
line[idx++] = b; // Add it to the buffer
return 0; // Buffer overrun
line[idx] = '\0'; // Terminate the string
// Line in buffer
if (target == VE_DUMP) {
// Diagnostic routine - just print to Serial0;
Serial.println(line);
// Continue on rather than break to reset for next line
label = strtok(line, "\t");
if (strcmp_P(label, ved_labels[target]) == 0) {
value_str = strtok(0, "\t");
if (value_str[0] == 'O') { //ON OFF type
if (value_str[1] == 'N') {
ret = 1; // ON
ret = 0; // OFF
sscanf(value_str, "%ld", &ret);
} else { // Line not of interest
lines--;
line[0] = '\0';
idx = 0;
return ret;
void VEDirect::copy_raw_to_serial0() {
read(VE_DUMP);
