View as source
I have just realized that there is a much better editing experience if you switch the edit box to View as Source.
It is faster, the spacing is laid out as it will be after it is posted and you can use all the familiar tags.
Also it has allowed me to put in links manually which I know will work. Everytime I have put them in with the fancy editor they have not worked so ( A ) I have had to check them after posting and then ( B ) to edit them.
Isn’t progress wonderful
…R
Turning off the WSYWIG editor really helped me (especially when using BBCode).
To make the editor behave as previous, I unchecked this option in the profile / forum settings / look and layout:
P.S. This post was made was made using quick reply. The "insert a link" button will now paste the link's path (including BBCode) correctly.
dlloyd: To make the editor behave as previous, I unchecked this option in the profile / forum settings / look and layout:
Thanks for that tip.
I have been deliberately keeping away from my Profile in case that caused even more trouble :)
...R
