View fuse settings
I had a project that was floundering because I was attempting to run an arduino at 3.3v (2xaa batteries), and the brown out detection was shutting things down at 2.7v. i have edited boards.txt and changed the brown out detection fuse to kick in 1.8v which is working.
-I am however still running the arduino at 16mhz, is this ok?
-Could I safely disable the bod?
-Does running the chip at 8mhz use less power? (I feel stupid asking this!)
-Can I set any 328p chip up to run from the internal oscillator and program it via the IDE, or will the timings be too far off?
-Is there any way to view the fuse settings of a chip?
Thanks!
Here is the original thread that set me on the correct path!
http://arduino.cc/forum/index.php/topic,75545.0.html
Sorry I dont know enough to answer your other questions, but you can view the fuses by running his sketch:
https://github.com/WestfW/fusebytes
Good luck!
It most definitely uses more power to run faster, less power to run slower.
Looking in the ATMEL doc (ATMEL ATmega doc8271.pdf) I see many different power options allowing use of less and less power just by running at lower and lower clock speed. That's not the only way to save power either. You can run at 128kHz internal oscillator or even an external 32kHz watch crystal if desired but don't forget that there is also a clock divider, the pre-scaler which may divide by powers of 2 from 1 to 256.
Factory default is 8MHz oscillator pre-scale divided by 8 = 1MHz, that is how the chips are shipped and they can certainly be ISP'd at that speed.
Your oscillator may be running at 16MHz but unless the default divider was changed, your clock is 2MHz.
Silicone may vary even across the same wafer. Some chips may get away with what others won't. The specs are made with margins in mind. But figure on this -- temperature matters so the edge you may be able to skirt now might just give you unreliable performance later.
9.2.1 Default Clock Source The device is shipped with internal RC oscillator at 8.0MHz and with the fuse CKDIV8 programmed, resulting in 1.0MHz system clock. The startup time is set to maximum and time-out period enabled. (CKSEL = "0010", SUT = "10", CKDIV8 = "0"). The default setting ensures that all users can make their desired clock source setting using any available programming interface.
9.11 System Clock Prescaler The ATmega48A/PA/88A/PA/168A/PA/328/P has a system clock prescaler, and the system clock can be divided by setting the ”CLKPR – Clock Prescale Register” on page 387. This feature can be used to decrease the system clock frequency and the power consumption when the requirement for processing power is low. This can be used with all clock source options, and it will affect the clock frequency of the CPU and all synchronous peripherals. clkI/O, clkADC, clkCPU, and clkFLASH are divided by a factor as shown in Table 29-12 on page 324.
What the Arduino board needs OTOH is the bootloader on the chip and perhaps oscillator and divider set for 16MHz to run properly?
@ Chris - that is just what I was looking for - thanks!! @GoForSmoke - Didn't realise speed affected power draw! I should really have used the mcu at 1mhz and left out the crystal, nevermind though, I have learned a huge amount about atmel chips recently! I don't really need speed with this project, just a low battery draw. It's amazing how versatile and flexible these chips can be!
Thanks again!
There are other power saving options. Here are a few selected parts on that:
  1. Power Management and Sleep Modes Sleep modes enable the application to shut down unused modules in the MCU, thereby saving power. The AVR provides various sleep modes allowing the user to tailor the power consumption to the application’s requirements.
10.3 Idle Mode When the SM2...0 bits are written to 000, the SLEEP instruction makes the MCU enter Idle mode, stopping the CPU but allowing the SPI, USART, Analog Comparator, ADC, 2-wire Serial Interface, Timer/Counters, Watchdog, and the interrupt system to continue operating. This sleep mode basically halts clkCPU and clkFLASH, while allowing the other clocks to run. Idle mode enables the MCU to wake up from external triggered interrupts as well as internal ones like the Timer Overflow and USART Transmit Complete interrupts. If wake-up from the Analog Comparator interrupt is not required, the Analog Comparator can be powered down by setting the ACD bit in the Analog Comparator Control and Status Register – ACSR. This will reduce power consumption in Idle mode. If the ADC is enabled, a conversion starts automatically when this mode is entered.
10.10 Minimizing Power Consumption There are several possibilities to consider when trying to minimize the power consumption in an AVR controlled system. In general, sleep modes should be used as much as possible, and the sleep mode should be selected so that as few as possible of the device’s functions are operating. All functions not needed should be disabled. In particular, the following modules may need special consideration when trying to achieve the lowest possible power consumption.
I do forget where I got the link to the ATMEL doc but LOL, here it is! Got to have the manual to RTFM! http://www.atmel.com/dyn/resources/prod_documents/doc8271.pdf
The first few times I dived into it, it put me into eyes-crossed or sleep mode but after a while I learned to recognize the material and can find whole sections to understand. That's normal for me and tech docs.
Yeah, a fair few people on here have referenced the datasheet, and I am slowly learning to read it. A lot of useful info densely tucked away in there - it’s deciphering it thats tricky!
The first few passes may be just learning to recognize words and context before you really begin to decipher what it's about. ;) But since the docs are not just nonsense and opinion (unlike say politics and other soap operas) but about actual things that work it does become possible to fully understand.
I expect that the MCU will crash well before it reaches 1.8v if it’s being run at 16MHz.
Officially speaking it takes 3.8v to run 16MHz.
In reality 3.3v is fine, but the lower you go the more likely it is that you’ll have issues.
If precise timing isn’t needed I would switch to using the internal 8MHz oscillator, or even the internal with the speed cranked down to 1MHz. That will buy you a lot of low voltage room.
If you need precise timeing RTC is the way to go. The Arduino crystal can not easily compete with any RTC in terms of long term stability.
Heh. I don’t know if this will make sense to anyone from a certain generation of Americans, but it’s cute…
By accident I connected a tiny to 9V. It survived more than 5 Minutes till I noticed it. I can not recommend it though ;)
inboxjason: I don't really need speed with this project, just a low battery draw.
An interesting thing I discovered recently was that by turning off brown-out detection altogether (via a fuse setting) I reduced sleep mode from 75 uA to 6 uA. That's a BIG saving!
So the irony is that using brownout detection to find when your battery is going low, can itself cause the battery to go low.
You may be able to get a tiny current draw by using a combination of sleep modes, watchdog timers, slow clock speeds, turning off internal features (like the ADC converter), and turning off brownout detection.
How come that you still draw >5uA? As far as I remember my experiments you can go down to ~0.5-1uA.
Good question. However in my test I think I was running at 16 MHz.
I am guessing that if I drop the speed down to 1 MHz I may get better results.
This may be the issue. I was running with an RC oscillator instead of a crystal. I think this reduced power consumption further. BTW: crystals with lower load caps will reduce power consumption as well. If a crystal is needed and frequency is being reduced (to decrease the voltage) it is better to use a slower crystal instead of prescaling a faster crystal.
