VIEW TEXT FILE ON ETHERNET SHIELD VIA LAN CABLE
Hello Everyone;
Am working on a project that requires me to write a text file to an SD card on the Ethernet shield.
To be able to view the text, I have to take out the SD card and plug it in my computer.
Is there a way I can view this text file without removing the SD card?
Can I in anyway be able to view this file by connecting a LAN cable from the Ethernet shield to my Laptop?
Thanks in advance.
You seem to have a problem with your Caps Lock key.
If you correct it, your question may be taken more seriously.
Yes, you can. Normally it will require server software on the Arduino. You can also use FTP or TFTP to transfer the file to your PC.
