Hello guys,
recently I might have burnt my arduino board.
It was attached to a motor shield via a power supply with some cables in the vin (+) and grn (-).
The copper of the cables is exposed and surrounded by tape. However I have noticed that some little wires come out from the position where VIN and GRN are on the shield. VIN and GRN are very close of course.
Is it possible that if they touch each other they would burn everything? Sorry, for the dumb question, I am very slow with electronics.
Thanks,
Francesco
Shorting Vin and Ground could fry your power supply, but it won't hurt the Arduino. Some power supplies will survive a short and some won't.
The Arduino can be damaged if you short the "wrong thing", or if you apply more than 5V to any pin besides Vin. So.... Be careful!!!!
If everything seems "dead" it's probably your power supply. You can test your Arduino by disconnecting the motor shield, powering the Arduino from USB, and running the Blink LED sketch. (That doesn't prove your Ardiuino is 100% good but it's probably OK, and if it doesn't work it proves your Arduino is bad.)
I think the arduino is fried because it is not recognized by the computer, on several computers. Though the LED turns on (just the power LED and the reset LED)...I am no able to upload anything because it is not recognized.
Thank you very much for the answer
