I am using a "Red Wings" on-board power supply to power a nRF24L01 breakout. I would like to use it to supply the UNO as well (since it provides regulated 5v).
Should it be safe to connect Gnd to Gnd and +5V to Vin on the UNO?
Should this power the UNO without using the 2.1 mm power jack or the USG input?
Gnd to Gnd is ok, +5 to Vin not so ok. Vin is the input voltage to the 5 volt regulator and it requires at least 7 volts or more to operate properly. If you are sure the breakout is providing a well regulated +5 then you could apply that to the 5V pin between the double ground and 3.3V pins. Be aware that Arduino.CC does not recommend this. Best not to have the USB cable plugged in and nothing plugged into the barrel jack.
Due_unto:
Glad I asked. I thought the 5 V pin was output.
Yes, aware of that. It's why I asked in the first place.
My whole object was to have only one input from mains. I am using the nRF24L01 breakout and they are sensitive to fluctuation in the 3.3 V supply they receive. The regulator fixes that but it means a second power infeed. By using the 5 V from the external regulator to feed the UNO I hoped to be able to get away with only the one mains feed.
vagulus:
As long as your 5 volt is well regulated it wont hurt the Uno. It WILL however backfeed +5 volts to any device connected through the Uno's USB port. This is why it's not recommended.
vagulus:
Uh Huh!
I'll just have make sure that I don't have the USB connected when the power supply is.
Thanks
Follow manner_royal's suggestion and use a USB cable to apply the 5V power. That way you must unplug the power supply before you plug into the computer's USB. Idiot-proof.
