i own a Arduino Mega 2560. Unfortunately i applied 7.2V/DC with the wrong polarity to my VIn-Pins. It fumes a little bit and now it´s no longer working -.-
This part fumed.
What is this part?
Is there a chance to repair it?
That should be about the easiest component on the board to replace. As a matter of fact, that is the culprit in another thread that I vented on this morning. If you replace it, I would do a Frankenstein on it. Use a "Lincoln Log" regulator, like a LM7805. I believe it is pin compatible with the smt unit that is currently there. Then you could use a small heat sink and use it with automotive voltage levels.
I would go with johnwasser's check. Does it power up and work with usb power?
This is Harrie and I blew the processor of my Atmega 2560. I removed the controller and replaced it with a new one. It does not work, so I first thought there might not be a bootloader inside, but I checked and also the clock is not running. Can anybody help me out?
harrievandalen:
Harrie
Impressive SMT skills! If you didn't program a bootloader onto the replacement chip it won't have one. You need to use the ICSP header and some programmer (or another Arduino) to try programming the 2560.
I think the AVR default fuses use the internal clock so you wouldn't expect to see the xtal oscillator running till it was first programmed - but could be wrong, anyone know for definite?
You are correct.
9.3.1 Default Clock Source
The device is shipped with internal RC oscillator at 8.0 MHz and with the fuse CKDIV8 pro-
grammed, resulting in 1.0 MHz system clock. The startup time is set to maximum and time-out
period enabled. (CKSEL = "0010", SUT = "10", CKDIV8 = "0"). The default setting ensures that
all users can make their desired clock source setting using any available programming interface.
