Vinculum VDRIVE2
Hello,
I have issues in order to setup the vdrive2 to my arduino.
Ths is what I have done:
-Pin1 (black) to minus
-Pin2 connected to Pin6
-Pin3 (red) to 5V
-Pin4(RX) to Arduino Pin1 (TX)
-Pin5 (TX) to Arduino Pin0 (RX)
-Set the jumper connecting UART to GND
Connecting the system to USB gives a red/green/red/green flicker of the vdrive. I plugged in my 1GB memory stick (formatted with FAT -not FAT32- under Windows XP).
I uploaded the following script (from playground) expecting VDRive something to do with the memory stick- but nothing happens...
int incomingByte=0;
int fileNumber=1;
int noOfChars;
long int valToWrite;
char activityToLog;
long int x;
long int startLogTime = 0;
      Serial.begin(9600);                    // opens serial port, sets data rate to 9600 bps
        Serial.print("IPA");                  // sets the vdip to use ascii numbers
                                              //(so I can read them in the code easily!)
        Serial.print(13, BYTE);               // return character to tell vdip its end of message
      if (Serial.available() > 0) {        // read the incoming byte
            incomingByte = Serial.read();
if (incomingByte=='1'){                      // if it receives a 1
  Serial.print("OPW LOG%");                  // open to write creates a file - named
  Serial.print(fileNumber);                  // LOG%1.TXT first time round - .TXT is for the computer
  Serial.print(".TXT");                      // I have used the % sign in the name so I can
                                             //search the disk for log files that it has created
                                             //so as not to overwrite any that may be on already
if (incomingByte=='2'){                      // if it receives a 2
               Serial.print("CLF LOG%");     // it closes the file
if (incomingByte=='3'){                      // if it receives 3
               Serial.print("DIR");          // lists the directory on the memory stick
               Serial.print(13, BYTE);       // which will now include the file LOG%1.TXT
if (incomingByte=='5'){
               activityToLog='P';                  // I will be using different letters to label my time stamps
               valToWrite=millis() - startLogTime; // time since we started logging
               noOfChars=1;
               x=valToWrite;                       // need to copy valToWrite as getting no of characters will consume it
               while (x>= 10){                     // counts the characters in the number
                 noOfChars++;                      // thanks to D Mellis for this bit
                 x/=10;
               noOfChars +=2;                      //add 2 to the num as will also write the letter P and a return character
               Serial.print("WRF ");               //write to file (file needs to have been opened to write first)
               Serial.print(noOfChars);            //needs to then be told how many characters will be written
               Serial.print(13, BYTE);             //return to say command is finished
               Serial.print(activityToLog);        //followed by the info to write
               Serial.print(valToWrite);
               Serial.print(13, BYTE);             //write a return to the contents of the file (so each entry appears on a new line)
if (incomingByte=='6'){
  fileNumber++;                                    //so we can create other files
if (incomingByte=='7'){
  if (fileNumber>0){                               //and look at previous ones
    fileNumber--;
if (incomingByte=='8'){
               Serial.print("RD LOG%");            //reads the contents of named file
if (incomingByte=='9'){
  startLogTime=millis();                          // reset timing
I searched the Internet for something to give me a hint, but failed. :-[ Can someone help me?
I just tied another code to get the data transfer LED to show activity..
int incomingByte=0;
int fileNumber=1;
int noOfChars;
char activityToLog;
long int x;
Serial.print("OPW LOG"); // open to write creates a file - named
noOfChars=1;
x/=10;
Honestly speaking- my TX LED on my arduino went crazyand I saw something happening on my serial monitor...but the vdrive still sleeps... :-/
I have worked with the VMUSIC2, a similar device with the addition of a MP3 player from the same people. Tie CTS Pin 6 to GND pin 1 and let pin 2 float. Also every unit I have ever gotten has a very early or low functioning firmware burned in and I must put the proper .FTD file in the USB stick root so that it will update the firmware to something that will recognize the commands I use. The .FTD file and utilities to modify it are on the Vinculum website.
Sorry I can't help you more as I never had a VDRIVE2 but I think if you investigate along the lines I suggest you might find some joy.
EE: What happened to the LED when pluggin in the Memory Stick?
My LED in the front panel basically shows nothing besided a red/green/red/green flash when putting 5V/ Ground to it..
the led flashes red and green for a few seconds when it first sees a new ftb file. After that it just flashes green a few times when it is powered up.
it also spits out >D:\ or maybe a short message if the USB stick is not installed even without talking to it.
I am still druggeling with the VDRIVE2. I cannot get ANY reaction from that &%§**?) piece of hardware >:(
Can someone lead me to a simple piece os sample code simply writing a useless number onto the stick? This would help as a starting point.
I appreciate any help!
