I've been working on a sort of self-learning robot recently and now badly need to visualize it's movements in 3D coordinate system on the computer. As a result of working, program on C++ puts out number of points coordinates. It also would be nice to make a kind of visual bonds between some points.
Could you please suggest any virtual environment program of some software, easy to interact?
Roborealm ($50) is a computer vision application that you can program to track your robot; a single IR led would be sufficient for a beacon to identify. It will then spew out coordinates which you would need to post-process on your own for the visualization you're requesting (I've never seen software that can do that). The resolution of your video cameras is the limiting factor on the accuracy.
If you ever happened to see the kinda-viral video of the MIT quadcopters performing well-controlled movements inside a room you'll note that they used computer vision to control the action. I'm saying that's relevant because it's improbable there are any better methods for position tracking. RTK GPS (10cm accuracy) is possible outdoors but it has a very steep learning curve and higher cost (~$400 baseline?).
Shesterinn:
If you already have the data in some format, then what you have is called a "3D Point Cloud".
I suspect that if you google for "3D Point Cloud Visualization Software", you are bound to find something that can work with your data.
I think, there is a bit of misunderstanding here: the point is to visualize movement of the number of points with coordinates, given by the running program. The problem is not to track the real movement, but to simulate it virtually.
cr0sh:
If you already have the data in some format, then what you have is called a "3D Point Cloud".I suspect that if you google for "3D Point Cloud Visualization Software", you are bound to find something that can work with your data.
Thanks, I'll look it up...
