Virtual Keyboard RA8875 & 7" TFT display "willing to pay"
Hello Guys,
i am currently trying to make an on screen keyboard and display what is being typed, i would also like to save what is typed as a string. currently i have set up the following code, the keyboard manages to upload to the screen but i lose touch feedback once i draw the keyboard, i was wondering if someone could collaborate on this.
thank you in advance
hardware:
arduino mega2560
RA8875 --> RA8875 Driver Board for 40-pin TFT Touch Displays - 800x480 Max : ID 1590 : $39.95 : Adafruit Industries, Unique & fun DIY electronics and kits
7.0" 40-pin TFT Display - 800x480 with Touchscreen --> 7.0 40-pin TFT Display - 800x480 with Touchscreen : ID 2354 : $34.95 : Adafruit Industries, Unique & fun DIY electronics and kits
#include <SPI.h>
#include "Adafruit_GFX.h"
#include "Adafruit_RA8875.h"
// Library only supports hardware SPI at this time
// Connect SCLK to UNO Digital #13 (Hardware SPI clock)
// Connect MISO to UNO Digital #12 (Hardware SPI MISO)
// Connect MOSI to UNO Digital #11 (Hardware SPI MOSI)
#define RA8875_INT 24
#define RA8875_CS 22
#define RA8875_RESET 23
Adafruit_RA8875 tft = Adafruit_RA8875(RA8875_CS, RA8875_RESET);     // LCD Screen
uint16_t tx, ty;
//#define IsWithin(x, a, b) ((x>=a)&&(x<=b))
const char textLimit = 18;
char MyBuffer[textLimit];
const char Mobile_KB[3][13] = {
  {0, 13, 10, 'Q', 'W', 'E', 'R', 'T', 'Y', 'U', 'I', 'O', 'P'},
  {1, 12, 9, 'A', 'S', 'D', 'F', 'G', 'H', 'J', 'K', 'L'},
  {3, 10, 7, 'Z', 'X', 'C', 'V', 'B', 'N', 'M'},
const char Mobile_NumKeys[3][13] = {
  {0, 13, 10, '1', '2', '3', '4', '5', '6', '7', '8', '9', '0'},
  {0, 13, 10, '-', '/', ':', ';', '(', ')', '
  {5, 8, 5, '.', '\', '?', '!', '''}
const char Mobile_SymKeys[3][13] = {
  {0, 13, 10, '[', ']', '{', '}', '#', '%', '^', '*', '+', '='},
  {4, 9, 6, '_', '\', '|', '~', '<', '>'}, //4
const char textLimit = 25;
void MakeKB_Button(const char type[][13])
  tft.textMode();
  tft.setTextSize(2);
  tft.setTextColor(0xffff, 0xf000);
  for (int y = 0; y < 3; y++)
    int ShiftRight = 15 * type[y][0];
    for (int x = 3; x < 13; x++)
      if (x >= (type[y][1])) break;
      drawButton(15 + (30 * (x - 3)) + ShiftRight, 100 + (30 * y), 20, 25); // this will draw the button on the screen by so many pixels
      tft.textSetCursor(20 + (30 * (x - 3)) + ShiftRight, 105 + (30 * y));
      tft.print(char (type[y][x]));
  //drawbutton(xStart, yStart, width, height);
  //ShiftKey
  drawButton(15, 160, 35, 25);
  tft.textSetCursor(27, 168);
  tft.print('^');
//Special Characters
  drawButton(15, 190, 35, 25);
  tft.textSetCursor(21, 195);
  tft.print(F("SP"));
//BackSpace
  drawButton(270, 160, 35, 25);
  tft.textSetCursor(276, 165);
  tft.print(F("BS"));
//Return
  drawButton(270, 190, 35, 25);
  tft.textSetCursor(276, 195);
  tft.print(F("RT"));
//Spacebar
  drawButton(60, 190, 200, 25);
  tft.textSetCursor(105, 195);
  tft.print(F("SPACE BAR"));
void drawButton(int x, int y, int w, int h)
  // grey
  tft.fillRoundRect(x - 3, y + 3, w, h, 3, 0x8888); //Button Shading
// white
  tft.fillRoundRect(x, y, w, h, 3, 0xffff);// outter button color
//red
  tft.fillRoundRect(x + 1, y + 1, w - 1 * 2, h - 1 * 2, 3, 0xf800); //inner button color
void GetKeyPress(char * textBuffer)
  char key = 0;
  static bool shift = false, special = false, back = false, lastSp = false, lastSh = false;
  static char bufIndex = 0;
if (tft.touched())
    //ShiftKey
    if (TouchButton(15, 160, 35, 25))
      shift = !shift;
      delay(200);
    if (TouchButton(15, 190, 35, 25))
      special = !special;
      delay(200);
if (special != lastSp || shift != lastSh)
      if (special)
        if (shift)
          tft.fillScreen(RA8875_BLUE);
          MakeKB_Button(Mobile_SymKeys);
          MakeKB_Button(Mobile_NumKeys);
        MakeKB_Button(Mobile_KB);
        tft.setTextColor(0xffff, 0xf800);
if (special)
        tft.setTextColor(0x0FF0, 0xf800);
        tft.setTextColor(0xFFFF, 0xf800);
tft.setCursor(21, 195);
      tft.print(F("SP"));
if (shift)
tft.setCursor(27, 168);
      tft.print('^');
lastSh = shift;
lastSp = special;
      lastSh = shift;
      int ShiftRight;
      if (special)
        if (shift)
          ShiftRight = 15 * (Mobile_SymKeys[y][0]);
          ShiftRight = 15 * (Mobile_NumKeys[y][0]);
        ShiftRight = 15 * (Mobile_KB[y][0]);
        if (x >=  (special ? (shift ? (Mobile_SymKeys[y][1]) : (Mobile_NumKeys[y][1])) : (Mobile_KB[y][1]) )) break;
if (TouchButton(15 + (30 * (x - 3)) + ShiftRight, 100 + (30 * y), 20, 25)) // this will draw the button on the screen by so many pixels
          if (bufIndex < (textLimit - 1))
            delay(200);
if (special)
              if (shift)
                textBuffer[bufIndex] = (Mobile_SymKeys[y][x]);
                textBuffer[bufIndex] = (Mobile_NumKeys[y][x]);
              textBuffer[bufIndex] = ((Mobile_KB[y][x]) + (shift ? 0 : ('a' - 'A')));
bufIndex++;
//Spacebar
    if (TouchButton(60, 190, 200, 25))
      textBuffer[bufIndex++] = ' ';
      delay(200);
//BackSpace
    if (TouchButton(270, 160, 35, 25))
      if ((bufIndex) > 0)
        bufIndex--;
      textBuffer[bufIndex] = 0;
      tft.setTextColor(0, RA8875_BLUE);
      tft.setCursor(15, 80);
      tft.print(F("                          "));
      delay(200);
//Return
    if (TouchButton(270, 190, 35, 25))
      Serial.println(textBuffer);
      while (bufIndex > 0)
        bufIndex--;
      tft.print(F("                        "));
  tft.print(textBuffer);
  Serial.println("RA8875 start");
/* Initialize the display using 'RA8875_480x80', 'RA8875_480x128', 'RA8875_480x272' or 'RA8875_800x480' */
  if (!tft.begin(RA8875_800x480)) {
    Serial.println("RA8875 Not Found!");
    while (1);
Serial.println("Found RA8875");
tft.displayOn(true);
  tft.GPIOX(true);      // Enable TFT - display enable tied to GPIOX
  tft.PWM1config(true, RA8875_PWM_CLK_DIV1024); // PWM output for backlight
  tft.PWM1out(255);
tft.fillScreen(RA8875_WHITE);
pinMode(RA8875_INT, INPUT);
  digitalWrite(RA8875_INT, HIGH);
Serial.print("Status: "); Serial.println(tft.readStatus(), HEX);
  Serial.println("Waiting for touch events ...");
GetKeyPress(MyBuffer);
byte TouchButton(uint16_t tx, uint16_t ty, int w, int h)
float xScale = 1024.0F / tft.width();
  float yScale = 1024.0F / tft.height();
/* Wait around for touch events */
  if (! digitalRead(RA8875_INT))
    if (tft.touched())
      Serial.print("Touch: ");
      tft.touchRead(&tx, &ty);
      Serial.print(tx); Serial.print(", "); Serial.println(ty);
//if ((x >= 0) && (x < _width) && (y >= 0) && (y < _height))
I'm currently working on a 5" version of the same thing using a Teensy. Where are you located?
-jim lee
Im located in NY, i am able to pull up the keyboard on screen, the issue is i lose the touch feedback and although the code compiles without any issue i know the buttons wont work correctly.
NY is terribly far away.
I do have code to do this, but I fear the learning curve would be incredibly daunting. Once you have this string, what would you like to do with it?
-jim lee
sorry for the delay, ive been extremely busy with this crisis. hope you are well.
i would like to save the string depending on where i clicked to bring up the keyboard.
like filling out an online application. if i click in name the string gets saved there. and if i click date i save the date there
