Virtual wire library won't compile
libraries\toneAC\toneAC.cpp.o (symbol from plugin): In function `noToneAC()':
(.text+0x0): multiple definition of `__vector_11'
libraries\VirtualWire\VirtualWire.cpp.o (symbol from plugin):(.text+0x0): first defined here
The only mention of 'vector' in the whole library is in virtualwire.cpp at the bottom:
interrupt(TIMER0_A0_VECTOR) Timer_A_int(void)
    vw_Int_Handler();
But commenting out this entire function makes no difference - the compile error still occurs.
So how do I pi$$ this error off?
Has anyone else encountered a similar library conflict involving Virtual Wire and how did you fix it?
Looks like you have two libraries trying to use the same timer. Rewrite one of them to use a different timer or find another library that uses a different timer.
Well it would help to begin to know where the hell, in all the Arduino files and folders, '__vector_17' is defined.
Visual C++ 2017 community 'find in files' function can find '__vector_17' anywhere.
It's an interrupt vector. Find interrupt 17 in the interrupt table in the datasheet of the micro.
Note that the error refers to a zero-based interrupt vector.
PS I now see that the exact interrupt is already mentioned by you.by the looks of it ;)
