Virtual Wire, need to be flushed each time?
I just playing with 315Mhz kit, communication goes well, but after second vm_send() message looks like if the receiver buffer goes hang, my question is, need i to flush the receiver buffer each time i do TX?
example: when i send (in loop section) after reset it sends data OK
Sensor Value:
456
BUT the second loop, it only show 3 chars
Received: Sen
Received: 362
the expected will be just as above
Received: Sensor Value
Received: 362
but it keep looping in the first 3 bytes, here is the TX code
connect the Transmitter data pin to Arduino pin 12
int j=0;
int analogPin=3;
#include <VirtualWire.h>
// Initialize the IO and ISR
vw_setup(2000); // Bits per sec
Serial.println("Starting");
char msgtx[10];
char prefix[]="Sensor Value:";
Serial.println(prefix);
Serial.println(strlen(prefix));
vw_send((uint8_t *)prefix,strlen(prefix));
vw_wait_tx();
delay(100);
j=analogRead(analogPin);
sprintf(msgtx,"%i",j);
Serial.println(msgtx);
Serial.println(strlen(msgtx));
vw_send( (uint8_t *)msgtx,strlen(msgtx));
vw_wait_tx();
void send (char *message)
vw_send((uint8_t *)message, strlen(message));
vw_wait_tx(); // Wait until the whole message is gone
Here is the RX code
byte message[VW_MAX_MESSAGE_LEN]; // a buffer to store the incoming messages
byte messageLength = VW_MAX_MESSAGE_LEN; // the size of the message
Serial.println("Device is ready");
vw_rx_start(); // Start the receiver
if (vw_get_message(message, &messageLength)) // Non-blocking
Serial.print("Received: ");
for (int i = 0; i < messageLength; i++)
Serial.write(message[i]);
any idea?, comments are welcome!
thank you
Try this:
TX code:
  vw_setup(1500);
  vw_set_tx_pin(12); //Set your tx pin
  char charMsgToSend[19] = "Sensor Value: ";
  char sensorValue[5];
  itoa(analogRead(A3), sensorValue, 10);
  strcat(charMsgToSend, sensorValue);
  Serial.println(charMsgToSend);
  vw_send((uint8_t *)charMsgToSend, strlen(charMsgToSend)+1);
  delay(2000);
RX Code:
  vw_setup(1500);
  vw_set_rx_pin(7); //Set your rx pin
  vw_rx_start();
  uint8_t buf[VW_MAX_MESSAGE_LEN];
  uint8_t buflen = VW_MAX_MESSAGE_LEN;
  if (vw_get_message(buf, &buflen))
    for (int i = 0; i < buflen; i++)
      Serial.print((char)buf[i]);
No, it is not necessary to flush the receive buffer.
However, it is necessary to set the received message length to the maximum possible value, every time before listening, as shown in the example above.
After a successful reception, buflen will be reset to the number of characters in the message.
Byork:
Try this:
TX code:
  vw_setup(1500);
  delay(2000);
RX Code:
  vw_setup(1500);
  vw_rx_start();
it works ok, so may be the diference between how do you declare the constants @t first time in the RX code (i just change the RX code part) as global?
as Jremington also point, if you put the declarations inside the loop thi can solve the buffer’s problem.
Tnx a lot
